Blade Extension Cuttin Edge Replacement
Dave (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Topic: Blade Extension Cuttin Edge Replacement
    Posted: 18 Feb 2012 at 6:40pm
Finally got around to checking into the cuttin edge at CAT for the extension.  Went to CAT.  Found a six foot cutting edge with three of the four holes that would match up.  Part #8D-2786.  $106.26.  Then had to have 18" cut off each end.  Three of the four holes will match up.  Following are some pictures.
Edge as the six foot.  Note that the cuts have already been made.
With the sextions cut and old edges.  Well I'm still having troubles with the picture post so will have to wait till it is operating properly.  But I plan on posting the pictures of the sections cut off and after mounting.  We'll see how the picture post thing works later.  Dave
Travis(NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2012 at 8:33pm
Cool! Keep me/us posted as I may have to do the same thing soon.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2012 at 8:41pm
Tried to post more pictures, but it's just not working.  Don't understand what's going on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2012 at 12:07pm
Seen the other post with pictures and they look good Dave. Do the holes in the new 6' cutting edge line up with the holes for the main part of the Allis blade?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2012 at 6:21pm
Travis, it appears that the holes for the six foot edge will line up.  The two end holes line up.  Then there are holes every six inches.  Consequesntly, that means there are holes in the edge that do not have holes in the blade.  Let me know if you have questions.  We still have to get together sometime, as we are so close.  Thanks, Dave
EdIL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EdIL Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2012 at 5:05pm
Guys,   FYI   You can save 1/2 if you buy 9W2297 cutting edge.  The difference is the 9W2297 is not heat treated, but otherwise the same.
Regards
Ed
michaelwis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michaelwis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2012 at 5:28pm
I got mine from the county highway shop .. used but free .. the one i have on my sc blade is 20 years old . Good as the day i got  it .Thumbs Up
WD WD45 DIESEL D 14 D-15 SERIES 2 190XT TERRA TIGER ac allcrop 60   GLEANER F 6060 7040.and attachments for all Proud to be an active farmer
