OK You WD Gurus...
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Topic: OK You WD Gurus...
    Posted: 16 Feb 2012 at 6:56pm
I have a 1951 WD that was purchased new by my grandfather and has made it's way down to me. I am very familiar with this tractor and its history. Dad had it overhauled about 25 years ago at the dealership where it was bought new. It has seen only light usage ever since that time. It still has the original 6 volt magneto system (the mag was overhauled about 10 years ago with limited use since). I use it mainly for raking hay now. My question is this; the engine has had a "skip" to it ever since it was overhauled back in the 80's and I can't figure out why? It seems to get worse the warmer the temp. gets and the more load it is under. I've replaced everything I can think of including plugs, wires, wiring harness, points, cap, rotor, kill switch, charge/light switch, carb kit, set timing, adjusted valves, put new screen in sediment bowl, gas cap. We have been fighting this condition for 25+ years and still it exists. Any ideas?
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2012 at 7:17pm
have you cked the rocker arm clearance?if you have a tight rocker it will do that when it gets up to temp.ck them all...
Boogerowen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boogerowen Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2012 at 7:27pm
Check manifold gasket........
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2012 at 7:31pm
Maybe start by checking compression a couple different ways and check for leak down in each cylinder. Check for leaks around intake and carb.????
Edited by CTuckerNWIL - 16 Feb 2012 at 7:33pm
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2012 at 8:22pm
Do a leak down test to rule out valves
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2012 at 8:28pm
I did have the exhaust manifold planed and put on all new intake/exhaust gaskets. It's not a steady miss where you can pinpoint it to one cylinder. It is intermittent, but definately worse under load with engine good and warm. I thought about converting it to 12 volt just to see if that cures it, but I don't know if it's electrical, mechanical or fuel related. It is very annoying.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2012 at 8:35pm
The voltage of the electrical system has nothing to do with how the engine runs if you have a magneto. The magneto generates it's own spark independent of the electrical system. When you had the mag worked on did it get a new coil? The old coils had a tendency to melt the insulation over time and will cause a miss as it heats up. Best test here would be to swap out the mag with one off a good running tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2012 at 8:46pm
Yes, it got a new coil when it was refurbished.
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2012 at 8:58pm
you might also ck for a valve seat loose...
WCTech View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WCTech Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2012 at 10:21pm
I am going to go out on a limb here. but I am thinking that there is a wild chance that the timing is off by a tooth or 2 when it was reassembled. My reasoning is because it will start and run fine when cold correct? Assumeing it does, I am thinking that when it is getting good and warm the "skip" you are hearing or feeling is a combustion "PING" from the timing being off and the spark occuring at the wrong time. This would explain why you cant pinpoint the cylinder where it is happening, because it is probably doing it on all for at different times. I am thinking it isn't the timing where the magneto is bolted on, but more the timing gears in the front cover.
Theory #2 - Is that the mag is getting a short in it when good and hot. Now this doesn't necessarialy have to be the coil. it could be the wire from the coil, bad ground, weak condensor, etc..... But since it sounds that it is mechanical I would go with timing, OR it very well could be the valve clearence is not correct once the engine warms up. I believe (off the top of my head) that the cold settings for the exhaust and intake is between .012-.015. I am not certain with out a book here. Or you may have a sticky valve that is not getting enough oil. Is this "skip" something you can physically feel in the performance of the tractor, or something you hear while operating it. That will also help to decypher. It may not even be the engine, maybe your hand clutch is out of adjustment and after it gets warm it may tend to skip also. Hopefully this helps.
Matt
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2012 at 11:49pm
I think I know the answer. Had a WD just like it with a fresh overhaul. Tried everything but you couldn't pinpoint the miss. To make a long story short it turned out that when it was overhauled the piston pins were centered in the rods and that let the pins rub on the cylinder walls and heat to red hot causing pre ignition. It got worse when warmed up. Pins, as we Allis people know should be installed with an offset. I hope this isn't your case cause you'll need new sleeves if it is. If you remove the oil pan you'll know by the scored marks on the sleeves.
Wink
I am a Russian Bot
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2012 at 9:52am
My dad would have me unscrew the sediment bulb body out of the buttom of the tank first. Hopefully it will be this simple. I have seen him do this more then once on old tractors he'll buy. They might have just enough gas to make them run, but not enough to make them run good.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2012 at 10:58am
Matt
Thanks for all the advice from everyone. Matt, I think you may be right about the sticky valve. I vaguely remember my dad saying something about that, I think he talked to the A-C mechanic many years ago. He's gone now so I can't ask him anymore. If that is the case is there anything I can do short of another overhaul? It does not do it all the time, but it will do it intermittently every time I use it long enough for it to get good and warm. Oil pressure is in the normal range.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2012 at 11:20am
Taking into account that this condition has existed over many years, and many different things changed and tried, and that it's been worked a fair bit over that timeframe, that with exception of a valve lash or assembly/lapping issue, the skip isn't related to anything you've changed, nor related to fuel quality.
I would not discount the magneto as being part of the problem, nor would I suggest that changing to a 12v electrical system would have any effect whatsoever, because of what Charlie noted above.  I also wouldn't predispose myself to assuming that since the mag is working, AND it was fully rebuilt a decade ago, that it's working properly.
In order for an engine to run smoothly, the ignition needs to be stable, consistent, and of sufficient energy to light the mixture.  Likewise, the fuel/air ratio needs to be stable and consistent.
What I WOULD do, is clear your mind of everything you know about the machine, and start over as if you know nothing.
Warm it up, until you can make it 'skip'.  Then SHORT one plug wire at a time (Don't lift it, because that will cause it to discharge elsewhere, and risk damaging the magneto or creating carbon-tracking in the cap and housing).
By lifting one at a time, you'll get indication as to which (if any) CYLINDER is affected.  The engine's note SHOULD change with each one lifted.  If you lift one, and it DOESN'T change the engine note, that cylinder is not firing.
Now... what you describe sounds like an intermittent miss.  IF you have one cylinder that is intermittent in firing, and you pull that wire, the intermittent miss will become a constant miss... it'll be smooth and rhythmic.
IF the miss follows one cylinder, trade the magneto wire and plug for a different cylinder, and try again.  If the miss follows the plug and wire, replace ALL plugs and wires, and when you do, make sure you're using solid-core wires and non-resistance plugs.  Magnetos don't operate properly with resistance wires and plugs.
If you find no change to the arrhythmia regardless of which cylinder, then what you're hearing either ISN'T a missing cylinder, OR it's a random miss of ALL cylinders.
A random miss could easily be the result of magneto problems- mag coil, condenser, or points.  Without a known-good-substitute, the possibility of proving the mag out is nonexistent... but looking to the other possibility would be a matter of altering fuel mixture to look for a change in performance.  With an intermittent miss present, pull the choke out a little bit, and see if the miss changes.  If it goes away, we have an improper mixture.  If it doesn't, it's still ignition related.
Mixture issues come in many flavors.  You described what appears to be load-related of a well-warmed engine.  I would suspect, by your description, that something that is getting WARM is changing it's characteristics, and one of the first things I'd check is the manifolds.  You said you planed the manifold, but there's more to it than the gasket interface.  I would warm it up good on a dark night, and put a load on it (PTO, or drive up a gravel country road with the hood off) and go looking for blue flashes of flame coming from places other than the top of the stack.  If this doesn't yield any clues, the next thing I'd do, is borrow an intake/exhaust assembly from a known good-running machine, and repeat the test.  Don't just change the manifold... change the carb and exhaust too.  IF this eliminates the problem, then your issue is either in the carburetor, or the manifold, or the exhaust.
One of the conditions I discovered that vexed me like yours, is a tiny crack in an INTAKE manifold runner of a (non-allis) industrial engine.  It exhibited a miss under high load and temp, and I eventually found that there was a tiny crack buried in that casting, that once warmed, engine expansion (block) and manifold expansion (heated carb base by contact with exhaust, like an Allis) would cause the crack to open up just enough to leak into THAT cylinder, causing a misfire.
Fuel/air mixtures that are in a very LEAN condition tend to become very difficult to ignite, hence a miss.  Many guys will 'throw parts' at an engine, oftentimes they'll solve problems like this by going to a 'racing/performance' ignition system, and since the miss goes away, they predispose themselves to thinking the stock system is inadequate, when in actuality, all they've done is masked the REAL problem, which is a tiny vacuum leak when warm.
If the intermittant miss occurs on all cylinders, the issue is most likely to be found closer to the carburetor.  It also may be that you have a crack within the carbeurator somewhere, and under cold running conditions,
And this is when I return the valve lash/lapping issue.  A valve that isn't seating properly will make a cylinder draw fuel/air differently, and the result is a miss.  Checking valve lash is always a good idea, but I would not jump into pulling the head until I'd checked everything else above.  My gut feeling is that the problem hexing you is successful at doing so, because it's incredibly simple, and incredibly tiny.
Eric B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2012 at 12:20pm
When you have the valve cover off check all the valve springs and make sure none is broken. Intermittent missing is not necessarily a characteristic of this, but more pronounced missing at warmer temps is, because of reduced because spring pressure reduces with heat. I've come across one Allis with exactly this being the problem.
Terry GA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Terry GA Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2012 at 4:21pm
My WD had about the same problem...changed out everything in the mag and it still skipped a little.Finally realized the wire going to the kill button on the mag was slightly shorting for some reason.The button did have a little rust on it but sure if that was causing it or not,but did remove the wire from the kill button and the skip stopped.Of coarse now to shut it off I have to shut the throttle off fast to kill it.When this mag goes out I plan on getting another one.
I couldn't repair your brakes, so I made your horn louder.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2012 at 8:12am
DaveKamp: You raise an interesting point about non resistor spark plugs for magnetos. I will check to see what plugs are in it. What are the right plugs for it? It does have new solid core wires.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2012 at 9:37am
JD's never had a kill switch. You just idled the engine back, held the brakes and pushed the clutch in to stall the engine.
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2012 at 12:54pm
Eric's point about a spring issue is a good one-  it doesn't take much spring pressure to make these old gals run fine, but if you had one that cracked... say right at the last loop... it might cause it to lean and bind just enough to get lazy when really warm.
As for plug type, I don't remember the number right offhand, but my only 'bend' out of anything, is to use a proper replacement per spec, but avoid Champions.  I've had very few spark plug failures, but the ones that did, were Champs.  SOmeone will chime in with an Autolite number soon.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2012 at 3:30pm
Autolite 295
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2012 at 3:48pm
Dusty
   Dusty, the proper way to shut a magneto ignition vehicle off without a kill switch is to shut the fuel off.
http://www.rumelyallis.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2012 at 8:07pm
I checked the owners manual and it calls for AC45 plugs. I looked at the tractor and it has AC R45 plugs in it, (R for resistor I assume). Is this my problem?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2012 at 9:17pm
R is for resistor. I would change them out to the AC45 or Autolite295
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2012 at 5:02pm
Found some Autolite 295's and put them in. I won't get to find out until spring if they help but she sure runs nice in the shed. Do you think this was the culprit?
This page was generated in 0.139 seconds.
