170 -175 rear weights?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: 170 -175 rear weights?
    Posted: 14 Feb 2012 at 10:32am
Any one have pics of a 170-175 with rear wheel weights mounted? I would like to see some. Thanks Tracy Martin
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2012 at 12:07pm
Bout the best I can do...still have to transfer all my file picks to the new laptop....
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2012 at 12:57pm
Eldon, are those weights for early D17, or for D17 IV and 170-175? Are the early D17 weights differant? I was wondering because of the wheel center change. Thanks Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2012 at 1:07pm
These are the correct weights for the D17 SIV and up through the 170-185 series with 28"  rims.  You can spot them by the little round knob them.
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2012 at 1:10pm
xxx
Edited by Eldon (WA) - 14 Feb 2012 at 1:10pm
ALLIS EXPRESS!
This year:
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2012 at 1:13pm
they should be correct for the series 3 and up to 185 with 28" wheels.
yes there was another casting for the older style of wheel center also.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2012 at 2:26pm
My parts manual shows the type I have. They won't fit my wheel without riding on lug bolt heads. They don't have the little round protrusion either. Thanks Tracy Martin
Lester View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lester Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2012 at 3:52pm
Both stiles will work.
NC Bruce View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NC Bruce Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2012 at 9:19pm
Tracy,  here's what came on my AC 175 high crop.  Don't drop on a toe when taking them off!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2012 at 9:26pm
I also  found out these segment weights fit on 38" wheels if they are reversed...but do inhibit lugbolt removal.
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2012 at 9:28pm
Bruce are those Rowe Foundry weights?
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote NC Bruce Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2012 at 9:31pm
Eldon or Tracy?  .....The rear weight that came with my AC175 (photo above)....is that an AC weight,  or an aftermarket one?
Was it intended for AC175,  or another model or make??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2012 at 9:35pm
Bruce it looks like an aftermarket....if it is AC it will have AMxxxx cast into it.
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote NC Bruce Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2012 at 9:38pm
Eldon;  you posted before I could ask you...ha!  Can you tell me more ?
I'll try to look at those weights tomorrow?
That's  the tractor that just started leaking oil out the manifold elbow...dripping down onto rails.  I'm afraid it's a ring or piston / engine problems??  Several AC fellows thought it might be injectors?   only 3600 hrs?
MBwcIll View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MBwcIll Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2012 at 10:57pm
The weights on 175 are AC weights, more popular on the 7000 series.  I'll check the AM number tomorrow and post it.  We kept them off our 7020 when we traded it.  I now have them on our D15.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MBwcIll Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2012 at 9:57am
I checked the number on our weights like the weights on "NC Bruce" 175.  Andy reminded me they actually started out on our 1974 200.
The number is; 25887
                      -02-WA
Perhaps the 300 pound D17 doughnut would appeal to your eye better.  Either way both styles of D series pie sectional, the WD, the above weight or even F&H weights will all work for you.  The 190/200 pie sectional weight would not work very well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2012 at 11:02am
Pics of them on a 170-175 tractor would be nice. Thanks Tracy Martin
dpower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dpower Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2012 at 11:20am
Bruce that is a factory AC rear weight ive seen them on 180 and 185s to.
Post Options Post Options   Thanks (0) Thanks(0)   Quote NC Bruce Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2012 at 9:52pm
Looked at those weights on above AC175D tractor (photo), and the numbers are:  256687-02-WA      Are these Allis Chalmers?  or after-market?
Tracy, here's some photos up close.  Is this what you asked for?  Let me know if you want more?  thanx,
Bruce Odel
Post Options Post Options   Thanks (0) Thanks(0)   Quote NC Bruce Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2012 at 9:53pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote NC Bruce Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2012 at 9:54pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2012 at 9:56pm
Bruce, they look like AC weights. Early casting had AM on them, I can't say on those. AC weights pictured in my book has 7 slots for bolts,4 grooves in register ring. How do you want to ship them. LOL Tracy Martin
Post Options Post Options   Thanks (0) Thanks(0)   Quote MBwcIll Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2012 at 7:01pm
I got to thinking, when I mentioned 300# D17 doughnut weights, there are two styles of them as well.  Both are Rowe Martinsville, IL foundry and use four bolts to attach.  One states D17 and has four small 1/2 round circles to allow room for the wheel rails.  The other style just says Rowe FDR and it has five areas to allow room for rails and valve styme.  The 190/220 doughnut weights will not work and have six bolts holes to attach.
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2012 at 7:52pm
I have the Rowe style 300 lbs on my 175, do you want a pic??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2012 at 7:58pm
Chris that would be great. Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2012 at 8:15pm
Pic of weight;
