20 Speed Transmission
KevinH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinH Quote  Post ReplyReply Direct Link To This Post Topic: 20 Speed Transmission
    Posted: 08 Feb 2012 at 11:56am
We have a steiger kr1280 that has a Allis 20 speed transmission. We replaced it a month or so ago and cannot get it to go into gear because of grinding gears. The only was is to shut the tractor off and then put it in gear. If anyone can help let me know. Thanks Kevin.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2012 at 12:07pm
With the engine off, you must have the clutch pedal cable "freeplay" adjusted to ZERO. The trans brake comes on when the pedal is clear down to the floor and if there's any freeplay, you aren't getting there........this is where to start. Anything other nthan this, it make get real ugly.
