Will 210 Year A Round cab fit a 190
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Topic: Will 210 Year A Round cab fit a 190
    Posted: 07 Feb 2012 at 8:39pm
Found a Year a Round cab that came off a 210, would it be the same configuration as that of a 190 or 200? Would it fit on a 190 without lots of work?
Thanks
Leon B MO
Darrell, Jr. (MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darrell, Jr. (MN) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2012 at 8:54pm
We put a QT1 Year round cab from a 210 on a 190.  We just bent up some new rear mounts, and took some tubing and mounted the front of the cab to the platform.  You will end up with a gap by the lower front windows, but a little sheet metal and some insulation and your good to go.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2012 at 5:34am
Thanks Darrell. It fits over the fuel tank OK? And mounts flat to the axle? We are looking to use it more as a canopy than a cab so it does not need to be air tight, we wont even put the glass in it, but I dont want it to look like its all cobbled up either.
Leon B MO
