Gas Gauge Float Sealer |
Michael (WI)
Joined: 12 Sep 2009 Location: Larrabee, WI Points: 815 |
Topic: Gas Gauge Float SealerPosted: 06 Feb 2012 at 6:15pm |
The next project on my list is repairing some D-series gas gauges. I have some new corks ready to go but I am unsure what product was recommended in the past to seal up the cork so it won't get water logged by our savior, ethanol gas. I seem to think it was a liquid product called Seal All, but when I went to ACE Hardware all I found was a semi-solid product by that name in a tube. Am I remembering the wrong name? What I use needs to be liquid so it can flow into the mounting hole in the middle of the cork. |
Ryan Renko
Joined: 12 Sep 2009 Location: Edwardsville, I Points: 2338 |
Posted: 06 Feb 2012 at 6:54pm |
Someone posted something about this before. They had a part# from a auto parts store that had a picture perfect replacement for the original cork one. I bought one and it works great. Maybe someone else can remember the store. It was made of plastic. Ryan
Chuck(ONT)
Posted: 06 Feb 2012 at 7:04pm |
I wonder if a small plastic gas filter could be sealed and attached to the float rod. Just a thought.
Never take life too seriously.
Nobody gets out alive anyway! 1C 1 WD45 1 AC180 |
Brian Jasper co. Ia
Joined: 11 Sep 2009 Location: Prairie City Ia Points: 10508 |
Posted: 06 Feb 2012 at 7:57pm |
The replacement float was for a model A Ford. Pretty sure it was Charlie that found the float. Mine has a brass float soldered to the arm...
JoeM(GA)
Joined: 12 Sep 2009 Location: Cumming,GA Points: 4897 |
Posted: 06 Feb 2012 at 8:12pm |
I've always used this stuff on cork floats
Lowes and HomeDepot used to always have it http://eclecticproducts.com/sealall.htm |
Allis Express North Georgia
41 WC,48 UC Cane,7-G's, Ford 345C TLB |
Michael (WI)
Posted: 06 Feb 2012 at 8:43pm |
First, thanks for the offers on the corks but I have those in hand already. Joe, that is the product I found at ACE...if it is the consitency of silicone sealant like I think it is how do I get it to flow through the hole in the center of the cork float? I guess I thought it was more of a liquid consistency. The gauge I am fixing had a perfectly good cork on it, except it had sunk. |
dustinmo
Joined: 12 Sep 2009 Location: Auxvasse, MO Points: 2187 |
Posted: 06 Feb 2012 at 9:07pm |
I got a bunch of corks a while back from a model T restoration place they were like 1.80 each and were already sealed, just to let you know , they are cheap and probally cheaper going this way than buying that sealer, they were the perfect size and work great, just look up model T or A gas gauge floats on the internet and you should be able to find them easy enough |
CTuckerNWIL
Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
Posted: 06 Feb 2012 at 9:25pm |
Perfectly good corks don't sink. Only corks that NEED replaced sink. You can throw away the cork float you have, buy 2 new neoprene floats that will never need sealing and have money left over. The sealer will cost the price of 2 neoprene floats and then you have the time involved messing with them. If you want "originality" pay a buck fifty for the sealed cork floats(model A Ford parts) and save even more money and your time. oldstandardautoparts.com has the neoprene float (which is resistant to ethanol) for about 4 bucks. Edited by CTuckerNWIL - 06 Feb 2012 at 9:32pm |
Gerald J.
Joined: 12 Sep 2009 Location: Hamilton Co, IA Points: 5636 |
Posted: 06 Feb 2012 at 11:19pm |
SealAll I what I have used and posted here. Its about the consistency of Duco cement. Its not like paint and I don't know what dissolves it. It won't flow, it will just allow itself to be smeared all over the cork and will probably plug both ends of the hole through the middle. It stands up to methanol, ethanol, and gasoline.
Gerald J. |
Dave in il
Joined: 22 Sep 2009 Location: Manville Il Points: 1748 |
Posted: 06 Feb 2012 at 11:29pm |
I just stop by the local garage and ask if the have any fuel pump/ sending units that they've replaced. They usually have some unless the trash was recently emptied and I can pull the float off for free. It's neoprene or some other plastic and will never need replaced and the price is right.
AGCO My Allis Gleaner Company
Michael (WI)
Posted: 07 Feb 2012 at 12:24am |
CTucker, I must have missed the whole Model A Ford talk in the past. I just did a search for a model A neoprene float and it looks like a pretty close fit. I was not looking forward otherwise to trying to seal the cork floats I have. I think I will give a neoprene float a try. Thanks for the info. Mike
David Maddux
Posted: 07 Feb 2012 at 5:26am |
I have used shellac on mine.
CTuckerNWIL
Posted: 07 Feb 2012 at 6:02am |
Call Kevin at Old Standard and ask for the neoprene gas tank float for the model A. |
David(Stockbridge)MI
Joined: 15 Sep 2009 Location: Stockbridge MI Points: 536 |
Posted: 07 Feb 2012 at 6:07am |
All "NEW" Web Site http://www.djstractorparts.com
2035,A,U,UC,WF unstyled,WF styled,WC High Crop (cane),RC,B,IB,C,CA,WD,WD45,G,D10,D12,D14,D15,D15 II,D17,D19,WC styled,WC unstyled H3 crawler |
Butch(OH)
Joined: 11 Sep 2009 Location: Lucerne Ohio Points: 3842 |
Posted: 07 Feb 2012 at 7:19am |
Maybe our fuel in Ohio is formulated differantly but I tried everything listed and more in an effort to keep the cork floats floating in my C6 Zeniths and none worked for more than a few months. This was with both the originals and the repros that used to be around. I could remove the floats and let them dry out for a week and they would again work for a few weeks before sinking, The fix only came when brass floats were adapted to the C6 float hinge.
CTuckerNWIL
Posted: 07 Feb 2012 at 7:27am |
Butch, Did you try the neoprene floats? They are supposed to be resistant to ethanol and I've never heard of anybody having trouble with them.
Butch(OH)
Posted: 07 Feb 2012 at 7:56am |
Charlie I dont recall anyone having them for the C6. We are happy with brass
JoeO(CMO)
Joined: 11 Sep 2009 Location: Cent Missouri Points: 2696 |
Posted: 07 Feb 2012 at 2:08pm |
Has anyone tried using Red Kote, the gas tank sealer?
D17JIM
Posted: 07 Feb 2012 at 2:29pm |
My fuel man gave me the rubber type float off of a broken tank gauge. It's worked for 6 years in my gas D17. Jim
