the ultimate wc
allismanamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allismanamp Quote  Post ReplyReply Direct Link To This Post Topic: the ultimate wc
    Posted: 04 Feb 2012 at 9:48pm
i have had this awesome idea in my head for ever but have always been thin in the pocket book to achieve it so i am hoping some one else does it i was thinking of putting a 6 cylinder diesel into a old wc allis and putting a cheap turbo of a gleaner on it that would be awesome  could have a wide front of a old wagon running gear and put a wd 45 diesel clutch and pressure plate in it so it don't slip with all that power then lastly have the injectors punched out and the pump turned up then put a 3 bottom plow behind her and watch the heads spin round while your plowing at the next field demo at the local show the old fellers wont no what to think of a wc pulling a 3 bottom plow in 3rd gear with smoke poring out that would be awesome i know my wc with a combine engine it draws a crowd around the dyno every year only thing had to do there is make a narrower pulley for the fan belt everything else slipped right in cheap power went from 16 hp to 45 hp for 300 dollars and had a tractor with 1000 dollars in it that competes with modified tractors with 3000 to 4000 dollars stuck into them at the local pulls and have turned some of the hot shot tractor pullers heads redAngry. i just love the old unstyled wc it is a fun tractor to putt around on
