SC Blade before and after
Goose View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Goose Quote  Post ReplyReply Direct Link To This Post Topic: SC Blade before and after
    Posted: 31 Jan 2012 at 3:00pm
Hey gang,
Here are before and after pictures of my snap coupler blade I bought this summer.
Before
After
JohnCinMd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCinMd Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2012 at 3:02pm
Looks good!
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2012 at 3:15pm
   Nice job ! Is that a stand or jack ?
http://www.rumelyallis.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2012 at 3:19pm
Yup, ya dun good !!!
I like the adjustable 'foot' for holding it up. Hope you don't mind but I'm going to 'steal' that idea for mine, when....I get around to repairing it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Goose Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2012 at 3:21pm
That is a section of pipe that someone has welded on the blade with a stand that slips through the pipe. You can put a bolt or pin through the holes to allow it to stand up by itself. It kind of binds a little on the tractor step when in the up position, but not too terribly bad. But if you look under the tractor, it also has a strap that I believe was the original way of holding up the end.
patrickmull View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote patrickmull Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2012 at 5:35pm
looks good
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2012 at 8:01am
got a close up of the stand and position?  Sounds like it should have been back just a couple of inches so as not to bind on the step when up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Goose Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2012 at 12:05pm
Ted,
Yeah, sure. You betcha!
Here you be.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2012 at 4:40pm
Goose,
 I see an accident waiting to happen. You should never use the bolt on arm latches with a Snap Couple tool. If the bell gets disconnected, the implement can and will flip up pinning you against the steering wheel. With the proper lift latches, it will disconnect at the lift arms before it hits you on the back of the head.
As far as the jack, if you straighten out that hangy down thing on the draw bar, you can pitch the jack. The original flat strap works great and you don't need to get off the tractor to put it down or up.
