Mid-MO AC mechanic
nsham View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nsham Quote  Post ReplyReply Direct Link To This Post Topic: Mid-MO AC mechanic
    Posted: 29 Jan 2012 at 5:53pm
I'm looking for a good AC mechanic in central MO.  I'm just south of Columbia in Ashland.  Looks like I need an injector pump overhaul on a 190XT and I'm not sure I have the time or skills to do it.  You guys were a great help in diagnosing the problem, so I turn to you again.
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2012 at 6:43pm
I,ll send you a pm , i,m in Linn Mo and prolly can work on this for you
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2012 at 7:45pm
I can do the pump work for you if you pull it off, or have someone pull it off. I can talk you through removal and installation if you are fairly mechanical. Good luck, Ed.
AC1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC1 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2012 at 8:56pm
I hear Capitol Diesel in Holts Summit does good work.  John Seimens is still doing ALOT of AC work in the old Henderson's Implement dealership location in Columbia also.  John is a very good honest mechanic.  Good luck.
JW
stray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stray Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2012 at 10:45pm
There is also Show-me Diesel in Columbia, John knows him very well. I will send you there # in a pm.
1969 190XT series 3
