Allis G Engine Problems
Prairierth View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Prairierth Quote  Post ReplyReply Direct Link To This Post Topic: Allis G Engine Problems
    Posted: 28 Jan 2012 at 10:31pm
Hello all.  I have been getting some help working on my G this winter from a neighbor who farmed with Allis' many years back, not a G specifically though.  Anyway, we have been having a lot of problems with it sounding like it was missing at an idle.  He rebuilt the carb and installed a new float.  All the plugs seem to be getting a spark, as we run the throttle higher it seems to get a little better but doesn't necessarily sound perfect yet.  I know it is a shot in the dark and the description is pretty vague but any suggestions?
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2012 at 10:59pm
Did you change spark plugs or wires?  Check points. I would start there. No resistor plugs or wires. Carb doesn't usually cause a miss. You could check the manifold for leaks. spray it with brake cleaner when it is running to see if rhe engine speeds up. Bob
ibleedorange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ibleedorange Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2012 at 4:24pm
I have the same problem with one of my G's. Did not check the manifold, but will now.
Tractors; If it runs, use it. Motorcycles: Ride em like today is your last day.
Tony.Or View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony.Or Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2012 at 4:37pm
Check to  see if  dist  shaft  is  sloppy,  that will give  ya  fits.   if points  are  bouncing  around  .  Tony
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2012 at 4:46pm
Maybe out of time a bit?I would check for vacuum leaks and then look at the timing.
Edited by CTuckerNWIL - 29 Jan 2012 at 4:48pm
Don(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2012 at 5:55pm
If your electric is ok, are you sure your getting enough gas through to the carb?
Just took the tank off our G today, blew air back through cause she was a little plugged at the bottom of the tank where the shut off valve is. Much better now, also cleaned sediment bowl and carb.
Galatians 5:22-24
This page was generated in 0.049 seconds.
