d15 clutch replacement
cobra View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cobra Quote  Post ReplyReply Direct Link To This Post Topic: d15 clutch replacement
    Posted: 28 Jan 2012 at 10:05am
this spring i plan on replacing the clutch on my d 15 gas.is this a big job and are parts expensive as i thought i should start buying them now.does the tractor have to be split to do this ( i'm not a mechanic) and what else should i look at while doing this (somemtimes pops out of third) can i do this my self im not a mechanic but can do minor repairs.  thanks  smitty
Brian S(NY) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian S(NY) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2012 at 10:41am
Yes,ou need to split it. Be very careful if you dont have the proper equipment to split it the job can turn into a nite mare. Find a freind who knows what to do and get them to help you. otherwise send it out. Parts are not that expensive. we did mine a year ago. Third gear problem is transmision. totally different work area.
Post Options Post Options   Thanks (0) Thanks(0)   Quote cobra Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2012 at 4:30pm
thanks for help                  smitty
