D17D Clutch? |
Post Reply ![]() |
Gordy ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: SWMI Points: 2533 |
![]() ![]() ![]() ![]() ![]() Posted: 28 Jan 2012 at 9:20am |
Just installed engine in my latest project D17D, Clutch pedal has several inches of
freeplay with adjustment all the way out and release fingers set at 2-7/16" as book says have new throwout bearing and clutch plate that appears to be correct thickness. clutch does release OK just seems to have too much freeplay on the pedal before it begins to release. I remember having same thing on a D15 but don't think I ever found why. Is this normal for these D series. |
skipwelte ![]() Orange Level ![]() Joined: 29 Oct 2009 Location: Anthon, Iowa Points: 723 |
As the clutch plate, flywheel, and pressure plate wear the freeplay will decrease. As long as the clutch releases, is adjusted correctly and isnt uncomfortable to use I wouldnt worry about it, sounds like everythng is right. HTH
WOW! Thanks for the quick response
JOHN N/IL ![]() Orange Level ![]() Joined: 11 Sep 2009 Points: 584 |
Gordy just curious what did you all have to do on your 17d .I have a 58 17d that we went through came out pretty good we really like this tractor .Ours has the narrow front and is all around a nice tractor.Good luke with yours,John
John. I got this tractor with a stuck engine have rebuilt engine. bearings, sleeves, pistons, rebuilt injectors and pump head had been done, all new tires.kind of a long expensive project but hope to have it done this year with new paint should be a nice tractor.
Post Reply ![]() |
