New building with AC sign?
rrhead(SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rrhead(SD) Quote  Post ReplyReply Direct Link To This Post Topic: New building with AC sign?
    Posted: 27 Jan 2012 at 1:31pm
ClapBuilding is finished, wondering what kind of sign I could put on it. Don't want to put a real expensive one on. Some of the e-bay signs are not very big. Maybe put a smaller one someplace else? What size should it be? Can you make a decal large enough that will work? Just looking for suggestions. Thanks, rrhead(SD)
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2012 at 1:38pm
   How big do you want ? How much room do you have on your eve ?
  And, I don't know where you got that logo recreation, but the A-C is way off center.
http://www.rumelyallis.com
split51 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote split51 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2012 at 3:13pm
Give me the dimensions you want and I can give you a quote on a sign for your building
1929 20-35 sn17662
B1 w/snow blade
B10 w/sickle mower
B110 w/mower deck
B110 w/tiller
B112 w/grader blade
B210 w/plo
JCSinPITTS,PA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JCSinPITTS,PA Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2012 at 3:21pm
Well I am interested in this also!
what are signs made out of?
how about 3 foot by 3 foot?
Post Options Post Options   Thanks (0) Thanks(0)   Quote split51 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2012 at 3:26pm
I can make them out of solid core plastic, thin aluminum sheeted on solid core plastic, 40 gauge aluminum or 80 gauge tempered aluminum. Or I can build can signs with lights in them and lexan faces.
  Here are two examples of the thin aluminum over solid core plastic signs I just built.
    The first sign looks bowed in the picture but it was just how my phone made the picture look.
Edited by split51 - 27 Jan 2012 at 3:39pm
1929 20-35 sn17662
B1 w/snow blade
B10 w/sickle mower
B110 w/mower deck
B110 w/tiller
B112 w/grader blade
B210 w/plo
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2012 at 4:46pm
I have a 4'X4' solid core plastic AC Diamond logo on my shed. It is 8 years old and looks like the day I hung it. It was done for about $175 back then, very happy with it. You may be able to go larger if you like, 5'X5'?
AaronH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronH Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2012 at 5:20pm
Congrats on the new building, really like the color! I think you should talk to Split51 and have a sign made that resembles the old Dealership signs that was simply....   ALLIS CHALMERS. Maybe 2.5 ft high and 10 ft long, or somewhere proportional. just my .02 This really got me thinking I need one myself!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2012 at 7:05pm
Split,
I'll have to keep you mind when we get our new Pole Barn up this Spring! Your signs look quite nice!
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote rrhead(SD) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2012 at 7:12pm
Thanks for all the suggestions. I was thinking 3x3, but maybe 4x4 would be better. I just copied the sign and had to crop it and then rotate it, so it probably got distorted. I like the Allis Chalmers sign idea. Will check into that. Will contact split and another one too. Thanks again, rrhead(SD)
Maybe something like this? I like the sign from split. May have to talk to you about that. rrhead(SD)
Edited by rrhead(SD) - 27 Jan 2012 at 8:13pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote split51 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2012 at 7:25pm
Thanks everyone. Here is an AC sign I built for my garage on the aluminum on plastic.  The orange is not the right color but I was just using up some old material.
  it is 8" x 60"
1929 20-35 sn17662
B1 w/snow blade
B10 w/sickle mower
B110 w/mower deck
B110 w/tiller
B112 w/grader blade
B210 w/plo
Post Options Post Options   Thanks (0) Thanks(0)   Quote JCSinPITTS,PA Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2012 at 12:41am
can you explain the different types of materials???
Kurzy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kurzy Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2012 at 8:06am
Howdy,
I sure like your new building. What you think of something like this lighted up there?
Kurzy
Austin(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Austin(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2012 at 9:07am
rrhead...that first picture you posted looks good! I designed the AC logo you are using in that one. I couldn't find a decent one online so I made my own! It looks damn good on the building! haha
"Better By Design"
