d14 parts
TREVMAN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TREVMAN Quote  Post ReplyReply Direct Link To This Post Topic: d14 parts
    Posted: 21 Jan 2012 at 8:24pm
Looking for a head, a rad, a front grill and hood center and side panels. Will d15 parts fit? Thanks in advance, Trev.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2012 at 11:16pm
I believe the D15 sheet metal is wider than the 14.  Hood center might fit though.  The rads are different as well.  The head might fit though.
David(Stockbridge)MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David(Stockbridge)MI Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2012 at 6:09am
have center , right and left hood, and new side panles for under gas tank. David
734-320-3470    www.djstractorparts.com
All "NEW" Web Site http://www.djstractorparts.com
2035,A,U,UC,WF unstyled,WF styled,WC High Crop (cane),RC,B,IB,C,CA,WD,WD45,G,D10,D12,D14,D15,D15 II,D17,D19,WC styled,WC unstyled H3 crawler
Rogers View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rogers Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2012 at 7:41am
I think the head is the only thing that will fit. I am pretty sure the sheet metal is different. Engine was the same though. I believe the D-15 side panels are just a little longer.
Think for yourself and be your own expert. Be willing to change your mind; however, willingness to change your mind doesn’t mean that you will. Blindly following any path is the pinnacle of insanity.
ac-mike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac-mike Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2012 at 12:25pm
I have the hood panels, an excellent rediator, and I believe I have a head but would have to check on that if interested. Located in central KY. Let me know.
