hardware to mount dual's ( wd)
Bob wi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob wi Quote  Post ReplyReply Direct Link To This Post Topic: hardware to mount dual's ( wd)
    Posted: 21 Jan 2012 at 10:19am
wanting to put duall's on the wd just because I got extra wd rim and tire's  anybody got picture's or idea's
Farrell(Utah) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Farrell(Utah) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2012 at 10:59am
I have seen the regular wheels used as duals.  One wheel is spun in against the tractor and the other dual is spun out.  Then two lug bolt holes are enlarged so two lug bolts will fit over them.  Then all but two bolts are removed from the inside dual and then the outside dual is put in place and the six lug bolts are put in place through both wheel centers.
A(1937), 2 G, 2 WD45 diesels, 6 WD45 gas, UC, 2 WD, D17 gas, WF, Farmall 400, D12, Kubota B3030
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2012 at 12:06pm
Usually the wheel center fits on the hub pilot tight enough you should be able to mount it with a couple of bolts, then remove them before installing the other wheel. Another way would be to take a couple of long lugbolts and  cut the heads off of them, (grind a couple of flats on them to get a wrench or socket on) and use them as pilots to help line the holes up when putting on the second wheel. Remove and replace with regular bolts when the other 6 are in. With no pilot diameter for the second wheel, I'd want all 8 bolts holding it on if it is a working tractor.
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2012 at 12:44pm
Bob, if you have need some wheel centers and eccentrics, let me know.   I know I have a set of them here.
XT in pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote XT in pa Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2012 at 2:22pm
i put them on my 17 for planting corn  i have hubs that bolt on the 4 bolt pattern like where you bolt the weights and they have an 8 bolt center
190XT,D17and 7045
