Bewildered, bedazzled and befuddled! Boiling WD
Farrell(Utah) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Farrell(Utah) Quote  Post ReplyReply Direct Link To This Post Topic: Bewildered, bedazzled and befuddled! Boiling WD
    Posted: 20 Jan 2012 at 7:02pm
My TlW loader has a WD motor in it.  After the motor runs a few minutes, the temperature gauge begins to move to normal temperature and then to hot.  At that point, the radiator boils over.  Thinking that it still has an old thermostat in it, I checked and the thermostat had been removed.  Here's what I know: (1)  The coolant level is full when it boils over, (2) the fan belt is tight, (3) when filling with coolant it guzzled it ran into the system as fast as I poured it in, (4) when the motor is running, it does not appear as though coolant is circulating in the top of the radiator, and (5) the water pump does not leak and turns freely.  Removing the radiator from this outfit is a major task so I would to that as a last resort.  Any ideas on what is wrong?  Thanks.
A(1937), 2 G, 2 WD45 diesels, 6 WD45 gas, UC, 2 WD, D17 gas, WF, Farmall 400, D12, Kubota B3030
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2012 at 7:04pm
It is plugged... your rad, might just be slush if its cold and your antifreeze is weak.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2012 at 7:07pm
"it does not appear as though coolant is circulating in the top of the radiator"
--- if the radiator is not plugged, then the water pump is not pumping.. you should see some movement, especially with no thermostat in it- water should POUR back into the upper hose to the radiator.
maurice View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote maurice Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2012 at 7:31pm
Is this new to you?  If so, perhaps the impeller of the water pump is worn off.  Or, re-direct the hoses so that you can pour water into the top engine hose and compare what comes out the bottom (can close off the bottom hose).  Then do same with radiator - how much water does it hold compared to what it is supposed to hold?  I do not know what a TIW loader is, so I don't know how hard it is to do this.  Obvioulsy, need to be careful (antifreeze mix) if the weather is too cold!
If you have had it a while, did this happen suddenly?  Mabe impeller broke off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2012 at 7:34pm
Sounds like the water pump gave up the ship! You may need a new pump there Farrell. We have em' in stock if it turns out ya need one..
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Farrell(Utah) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2012 at 7:59pm
The problem arose last summer and the coolant level was low.  However, filling it to the top did not solve the problem.  Thanks for suggestions on checking the radiator flow.  The motor and radiator are all new to me so I have not had experience with them before.  Can an impeller go south and have the pump not leak?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2012 at 8:21pm
Absolutely. My WC's impeller was shot. Didn't leak a drop!
Steve@B&B
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2012 at 8:28pm
Sounds pretty serious to me, should I drive out there and take it off your hands?
E7018 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote E7018 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2012 at 8:37pm
I need to tear into a 301 that is doing the same thing. Top of engine would be hot but not radiator. Thermostat, water pump, piece of shop rag lodged somewhere?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Farrell(Utah) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2012 at 9:31pm
Lonnie,
  It could be pretty cheap right now.  These things are absolute beasts to fix anything.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2012 at 10:58pm
I could use another project.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2012 at 1:26am
With the impeller pressed on the shaft, it can split. I had a '68 F350 that would overheat about ten miles from home, (big block, supposed 390 4 barrel carb with a 5.13 rear axle). When i took the fan belt off, I could spin the water pump shaft with my fingers and it would coast at least half a turn. Not loaded by water or seal, though it wasn't leaking. I didn't open it up because that killed the core value. With a new pump I could run it as far as I could afford gas, about 9 mpg loaded or empty if I kept it under 60. Dually.
Gerald J.
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2012 at 5:54am
Maybe timing is retarded!
stray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stray Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2012 at 9:11am
Yes, if the timing is off it will run warm to a little hot, but if timing was that far off he would be complaining about how it runs also.
Edited by stray - 21 Jan 2012 at 9:22am
1969 190XT series 3
Post Options Post Options   Thanks (0) Thanks(0)   Quote Farrell(Utah) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2012 at 9:44am
Thanks to all of you for your responses.  After sorting through everything and thinking about the problem some more , I think that it is a broken impeller in the water pump.  I must admit that a "toasted" impeller would not have been on my hypothesis list.  Given the way fluids have moved through the radiator and block, I don't think there is a blockage.  However, after the pump is off, I will test for flows as some of you have suggested.  Timing is not an issue as it runs too well to be out of time.  Cheers to you!  It is nice to have a team of experts so willing to assist.  Many thanks.
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2012 at 9:54am
Farrell,  It seems you have solved your problem.  Just be sure the water is flowing through the block.
We had a B whose block was full of mud.  They had a leaky radiator and could not fix it quickly so they were putting in stream water when needed.  Trouble was the stream water had settlement in it and it plugged the block.
Good Luck!
Bill Long
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2012 at 9:58am
If you pull the top radiator hose off and crank over the motor, water should shoot out the hose... with no thermostat installed.
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2012 at 12:16pm
Yea, sounds like bad water pump.  Ive had impellers come loosw and spin of the shaft resulting in no coolant flow.   Had it hppen on an engie Id overhauled, took a while to get it thru my head the remanufactured water pump had a slipping impeller.   Good luck.
