ac-g rear cultivator options
BillyT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BillyT Quote  Post ReplyReply Direct Link To This Post Topic: ac-g rear cultivator options
    Posted: 20 Jan 2012 at 1:40am
hey, I'm new to the forum by way of my new ac_g that i recently acquired to use as a cultivator on my farm. I don't have the rear cultivator setup except for the attaching arms but I think I found a rear manual lift setup but I  want it to be hydraulic. It seems like a relatively easy modification that could be reversed if you ever wanted to. I tried to search but no luck. It seems like you could use a 2 way hydraulic cylinder and a control valve. What would be a good spring alternative? Are springs like that available? Thanks for the help. I'm really exited to put this beauty to work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BillyT Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2012 at 1:13pm
any ideas from the informed? Thanks.....
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2012 at 6:19pm
I'm in Florida for the winter, my G and books are home in Michigan. I do know that the rear has a remote cylinder with a needle valve that gave it a delay.
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote BillyT Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2012 at 6:41pm
thanks for the tip and reply. I figured for sure someone had a picture or experience of a rear furrow mod. from manual to hydraulic. I'd rather pick up the hydraulic parts but they seem to be hard to come by. Any help is appreciated. Thanks.
Allen Dilg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allen Dilg Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2012 at 8:11pm
  Hello Billy  And WELCOME    I'm in a similar situation, I need the whole hyd system, but now I am looking for a complete hyd "G".     Would consider trading 2 running "G"s.   Good luck
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2012 at 7:27am
uploads/351/g.jpg
does this help ?
Not mine...sigh....
