Rebuild of WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Topic: Rebuild of WD45
    Posted: 19 Jan 2012 at 7:22am
There are a few strings on here with different questions of rebuilding the 45.  I am still a newbie when it comes to all of this and I have quoted others from other strings and have questions.
Originally posted by 79fordblake 79fordblake wrote:
While your at it might as well order the D17 piston/sleeve kit so you will have about 50HP. That will be the route I'm going in the future.
I have heard this quite often on here.  Is this true?  Just changing these two items can do this?
Originally posted by Glockhead SWMI Glockhead SWMI wrote:
I wonder if the aftermarket offer different kits for the 46,d17, 170.... I bet all 226 engines use basicly the same kit.
Are there any differences??  Are they the same?
d17brown View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote d17brown Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2012 at 7:46am
a high compression kit for a 170 will work in the wd 45 , did it and have compresson of 170 psi on each cylinder, are trying to make more hp or just use for parades,there are different tricks you can do
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2012 at 7:52am
If main bearings comes with kit you will have to buy main bearings. 170 mains and WD45 mains are different.
  If your 45 is not 12V it will need converted.  MACK
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2012 at 8:00am
You may also need to increase engine speed by using a different governor spring in addition to the sleeves and pistons to achieve the horsepower. At some point while you fine tune you may also have to do some carb work or change to a larger capacity carburator.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2012 at 8:42am
Its not that simple to just make 50 HP, although these AC engines seem to respond very well to small changes. Compression = HP but it takes a lot of other small adjustments and revisions to make the combo work. Ask anyone who is serious about Tractor pulling and they'll tell you. Sometimes it takes a while to get the right combination (and that's part of the fun and experimentation) but once you get on a roll with that combo and things start working and falling into place, look out competition! Also helps in the wallet department to for some cash flow to make that combination come together. LOL!  Some of our Orange family members here have shown us some pretty cool stuff for engine mods and scratch built mountain motors. If your a gearhead like me, you can appreciate their efforts quite a bit! Love some of the combinations and trick stuff some of these gentlemen do to these engines to make em' talk, and keep Allis-Chalmers on top of the heap!. There's nothin' wrong with an Orange PO#1 or #2 Tractor with a serious attitude...
79fordblake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2012 at 9:47am
Unless I understood DrAllis wrong:
"Anything you do will require 12 volt starting. If it was MINE, it would get a std D17 AGCO piston/sleeve kit, which raises the compresssion from 6.5 to 1 to 7.25 to 1 and will increase the HP from 43HP to probably 53HP at 1400 rpm's. Believe me, that is enough to rip all the teeth off of the PTO gears if you ever get rough with it. The kit drops right in with no hassles and will still sound like an AC PowerCrater engine"
Crank is different in the D17 so the main bearings will not interchange among the two. The D17 makes more HP than the WD45 b/c of higher compression and it runs a tad bit faster. So 50HP is pretty much a drop in for this engine. I would go with the D17 governor spring also to raise RPM.
Yes there will be "tuning" involved but there is always "tuning" involved when rebuilding a engine.
Edited by 79fordblake - 19 Jan 2012 at 3:58pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2012 at 3:56pm
Where do you get a D17 spring?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2012 at 3:59pm
Agco still has them...I've heard they are fairly pricey. I'm sure you could find a good used one.
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2012 at 5:24pm
My WD made 50 on the dyno with a 45 crank, head, carb, intake and an AGCO engine kit for a WD45.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2012 at 5:46pm
I hate to burst your bubble, but that was measured on an M&W dyno wasn't it?? If it was a factory stock WD45 piston & sleeve kit and everything else is absolutely stock your HP ain't really 50...it's still 43 hp. Really low air temps add to the 43 but an M&W dyno is notorious for reading a little high. Diesel engines can be given more fuel to increase the HP, but gas engines (if every thing is still bone stock) just don't make more than they were ever rated at....they can't.....sucks, doesn't it?? Now, a WD45 making 53 hp with a D17 motor kit in it is possible because the D17 was rated WITH power steering and many WD45's don't have that PS HP drag on them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2012 at 8:01pm
Which spring is it?  I found 2 on their site
74050179 : Spring, governor control
74048624 : Spring, governor linkage
Brampton 02 gt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brampton 02 gt Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2012 at 9:43pm
The spring is about $65 from Agco.
I think it is 70229519  spring with plunger.
pretty easy to change with pliers.  Easiest without rad on.
A&I and other aftermarket companies sell high compression kits for the WD45.  I assume these must be similar to D17 kits.
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2012 at 10:33pm
compression is always a trump card. It allows so mcuh more wiggle room . cam duration etc. 12.1 compression ratio 240ci with a mild  head flow of 150 cfm 170 cam rocker geometry fixed to get net valve lift not counting about 6 degrees more cam duration from the 1.85 rocker change will make conservative 75 horses usually more but if i was selling i would go conservative to make purchaser happy. after all 8.1 226 with 170 cam and shoddy rocker geometry and less air flow is usually 60 hp.
Edited by mlpankey - 20 Jan 2012 at 10:36pm
This page was generated in 0.043 seconds.
