D-17 226 adding turbo
kerrdawg40 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kerrdawg40 Quote  Post ReplyReply Direct Link To This Post Topic: D-17 226 adding turbo
    Posted: 17 Jan 2012 at 11:12am
Was thinking about adding a keystone turbo kit to my D-17 226 GAS  . There website stated that I would need a bigger carb .  Could someone enlighten me on what size carb I would need to go to and info on where to get it . Engine is stock and with changed govenor spring turns around 2100 -2200 rpms , have turned up to 2800-3000 with a pull on the extra throttle I installed. Tractor used for pulling comp . only .
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2012 at 11:55am
at least double the size of what you have now. rule of thumb 15 psi of boost double the horsepower. turbo needs to move at least 300 cfms of air or its a waste of time.
Edited by mlpankey - 17 Jan 2012 at 12:13pm
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2012 at 12:03pm
I have a Zenith 12957 off a 262 Gleaner that should feed that.   Your stock cast iron  fly wheel could grenade at hi rpm,  and the power director clutch may not be safe at 3000 rpm, either.
KGood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KGood Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2012 at 12:12pm
Or a 301 gas carb with a bigger venturi. I'd like to do that to someday with my WC.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2012 at 3:45pm
Is is possible to put injectors in and eliminate the carb? I'm sure it's been done.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2012 at 5:49pm
yeap its possible
Larry(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2012 at 5:09am
I had a bendix(if I remember right) off a G gleaner on my WC witht he hot cam in it.  I never had a fuel problem with it.  Sold the manifold to someone on here that I had made where there was no overhang on it.
'40 WC puller, '65 770 Ollie
*ALLIS EXPRESS contact*
I can explain it to you, BUT I cannot understand it for you!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2012 at 6:32am
What is your plans for rods?  MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2012 at 6:56am
GREAT POINT, MACK !!.......and if a tractor like that showed up at any Pull around here, I doubt it would be allowed to even hook to the sled.......Why, you ask?? well first, what class are you going to put it in ?? and with zero safety equipment, no insurance company would want anything to do with it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kerrdawg40 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2012 at 9:33am
Mack are you saying the rods will not hold up at 2100-2200 rpm with a turbo charger, just asking before I put one on it . Also Dr. Allis  there are under 3000 rpm  farm classses without a blanket and you can run a turbo . Didnt know that since I had an antique tractor I was limited to antique  pulling classes. Just enjoy pulling .
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2012 at 9:45am
Rods will be a issue .
Post Options Post Options   Thanks (0) Thanks(0)   Quote kerrdawg40 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2012 at 10:57am
Ok thx, for everyones input .
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2012 at 9:48pm
The D17 rods will fold up with turbo boost and when they do it will try to push the crank out the bottom if it don't burn a hole through your cast aluminum pistons first. MACK
