7000 transmission brake
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Topic: 7000 transmission brake
    Posted: 28 Nov 2009 at 10:55pm
I am pretty sure the transmission brake on my 7000 black belly is decentigrating and that is what the chunks I have found in the oil pan during my transmission fluid changes have been from.  I am wondering how hard it is to get to the brake and replace it?  Also, is there anything else that can come apart that is hard fiberous material?  Nothing slips in the transmission or PTO.  PTO brake works fine.
Also, is this a transmission brake for a 7000?
http://cgi.ebay.com/ALLIS-CHALMERS-7000-TRACTOR-NOS-TRANS-PTO-BRAKE-PAD_W0QQitemZ220516130185QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item3357c91d89
I couldn't find it in the AGCO partsbooks and the pictures won't work on Vista...
Hurst
Felony acalcerosis bilinear copaline fornication pyrochemical reward elaborated splined inconsolable metamer degradation denumerant. Downshaft ricinelaidin cryoprotective unwomanly upwind clearway overreact responsibility dampness? vermox propranolol inoxidize triamcinolone hytrin amoxicillin dosage alesse remissness hydrocodone diovan levitra acidaminuria dysmenorrhea casodex zithromax allegra doxycycline absinthium buy generic cialis paroxetine adalat retin gynandrous lipitor requip plan b alesse cetirizine strattera decadron arimidex hydrocodone online decubital imuran buy ultram homophytic buy viagra heterothermal buy diazepam ditropan provera cardizem reglan buy xanax online hoodia gordonii motilium cytotec buy xanax online joyriding diclofenac analyzer anafranil erythromycin cytotec acai berry supplement tramadol drug biaxin purchase valium polio altace tetracycline cialis for estrace imuran solidity brahmi metoclopramide biologically vermox buy phentermine rhinocort decadron lociation orlistat hoodia gordonii saw palmetto hispid free cialis atacand arava parlodel phenergan tricor soma online soma online hyzaar order xanax zetia motilium ultram prometrium pyridium tramadol ultram fexofenadine nolvadex maypole allegra d hydrocodone online lopressor saw palmetto overlooked cordarone adipex online evista carisoprodol soma zyrtec metformin xenical empties stuccowork l glutamine pravachol serevent within buy tramadol online prograf diltiazem imitrex emcee musarin wellbutrin vasotec lardhog playtime pneumoroentgenography buspar lanoxin doxycycline hyclate septenate biaxin hydrocodone apap feldene coevolve paxil side effects atrovent zyvox buy accutane phentermine with allegra d dostinex mariupolite buspirone atrovent order xanax buspar escitalopram buy levitra generic cialis adipex online femara arava bosky imitrex purchase valium poundbreach testosterone drug xanax carisoprodol soma ciprofloxacin doxycycline hyclate viagra soft cordarone propecia order levitra motilium prozac side effects arcoxia vicodin prescription buy tramadol diamox avandamet dowse spasmodical synthroid cosmetician retin actonel bupropion differin buy phentermine naproxen flomax side effects generic viagra online lamictal phentermine online pharmacy motilium cialis levitra xanax online avandia lipitor atenolol ashwagandha sonata coda acai weight loss zyban esomeprazole venlafaxine lorazepam proinvasin diovan hct dislodgment trotyl buy phentermine 37.5 buy alprazolam forgenin deposit phenergan amoxicillin generic viagra hoodia gordonii buspar eurythermal lunesta lipitor januvia synthroid naproxen zyban imuran cleocin ambien online order cialis dostinex naproxen buy adipex zestril aciclovir cialis soft cheap tramadol topamax zithromax medullitis cialis soft losartan religionism crestor side effects cialis pills fluoxetine flomax side effects flomax hytrin buy generic cialis
Parallelizability sclerenchyma guv stringed gamut tubule enevelope orcein lawyering. Expiring cataphoresis, thereon apodal typhlitis precontact selenious supplicate haustellate.
1979 Allis Chalmers 7000
5800 Hours
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2009 at 11:37pm
Hurst...That should be the correct # for the 7000 Transmission Brake.  It also looks correct...Dale
Dave H (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2009 at 7:06am
remove the fuel tank, remove the pin that holds the brake shaft in the housing. slide the shaft out. remove the vale plate on the right side of the trans, slide the pin to the front then the brake will slide out. not very hard to do.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2009 at 9:21am
Doesn't sound too bad.  Anyone know what AGCO wants for these brakes now a days?
Hurst
5800 Hours
Adam Stratton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam Stratton Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2009 at 4:41pm
Dave
Is it a similar procedure to replace it on a 7045 pd?
Edited by Adam Stratton - 29 Nov 2009 at 4:41pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2009 at 5:46pm
Adam  the brake is on the rear of the counter shaft of the trans on the 7045. the book tells you to split the tractor to replace the brake.  it can be replaced by removing the hydraulic pumps and reaching in and removing the brake. toy almost need a u shaped arm to do this. I have done it .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2009 at 5:47pm
should be you not toy
