pertronix ignition
vyvyjim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote vyvyjim Quote  Post ReplyReply Direct Link To This Post Topic: pertronix ignition
    Posted: 12 Jan 2012 at 11:22am
Will pertronix ignition add any horsepower to my series IV D17?
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2012 at 11:25am
Probably not, but it will start easier , run smoother, and spark plugs will stay cleaner & last longer.
  I thought I'd edit my reply, because I simply responded to  question, but I'd like to add that once you install a pertronix and an appropriate coil, there are two things I do that I think add a little more power. The first is to trim the outer electrode back to where it ends directly above the side of the center electrode, I do this with a 3" disc cutter, and finish it with a small file, make the trimmed electrode square and sharp. Electricity will jump from one square sharp edge to another much more easily than  from one rounded [worn] electrode to another... much less resistance ! Work carefully , try not to nick that center electrode. Next , reset the plug gap to 40- 45 thou. Need a wire gauge to do this properly, feeler gauge is hard to use.   Then, to back up a little, when you buy plugs , buy twice as many as you need, mark on each one on the porecelin where the open area of the eletrode is and try each one in a cylinder , the object is to index your plugs for each cylinder so that the outer electrode is up, the flame or spark faces the piston. This will increase the power, of course you can index plugs with points and see some gain , you can't open the gap and make a big fat spark as I have described here. A mag in tip top shape might work just as well.. I know that I have a lot of respect for a magnetos spark !
Edited by Gary in da UP - 13 Jan 2012 at 4:02pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2012 at 3:54pm
The Pertronix Ignition won't add any HP, but it does add reliability.  Eliminating the points and condenser is big in the plus department! Faster starts as Gary mentioned, also an even amount of current to each spark plug. A hotter coil can be added also if so desired for a little more fire in the hole making for a little better combustion. Cool part is it fits right inside the stock Distributor with no mod's, so looks stock as can be. We sell quite a few E.I. kits. Usually when one is purchased and installed in one Tractor to try it out, the rest of the Tractors wind up with em' to!  LOL!
Steve@B&B
79fordblake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2012 at 4:06pm
All my tractors start before you have time to let off the starter...don't see how the pertronix can make it start any better. My WD45 had the same plugs and points in it for 20 years and Grandpa used it alot. Just this year I gave it a full tune up.
Pertronix will make a tractor start faster if it is out of tune...and it makes them run better in pulling applications. Seems like wasted money for a field tractor but alot of people love them.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2012 at 5:33pm
I put one on my series IV when I restored it 5 years ago.  It dyno'd at 58 hp.  The guy operating the dyno told me I could have hit 60.  Never tested it before the Pertronix.  I will say that it is a very nice piece and worth the money.
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2012 at 5:42pm
We sell quite a few of them, but I try to keep people realistic.  If your points and capacitor is good, you will not see a bit of difference.  But if things are weak, you will notice.  I only recommend them on 12V systems, and even then I try to give realistic expectations.
I'm actually the opposite of 79, if I had to rely on mine for field work, I would be more apt to put one in more of my tractors.  For occasional use I can file points if she doesn't start up.
JimD
NickT(Ky) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NickT(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2012 at 5:44pm
Ive got them on Allis' and farmalls. Love'em.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2012 at 7:56pm
I have heard of many people having trouble with pertronix on other sites. Together me and my dad have 7 tractors with points still and I have one truck that still runs on points....never been a time they wouldn't start. I'm keeping my money in my pocket for other things. Most of my buddies have pertronix but they have built up engines. There stock tractors still have points.
I have seen side by side comparasions on same brands and models of tractors...the pertronix doesn't make the tractor run any better than a tractor with a good set of points that are adjusted correctly.
Not trying to argue with anybody just saying what I think about it. To all the pertronix people....id keep extra set of points and condensor in the tool box...b/c you never know when that little module will leave you stranded in the middle of a tractor ride or the field. The local farm store will more than likely have a set of points you can use...but they won't have a pertronix module.
TREVMAN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TREVMAN Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2012 at 9:31pm
Ive converted 9 engines with Pertronix, never had one fail, there is no comparision to points. If it starts better and runs better, it will have more power. Converted 2 Ford 361s, absolute dogs before, much more power now, no choke to start, and use less fuel. Of course points work, theyve worked since the begining of mass produced internal combustion engines, but there has been better technology available for 40 years, my 2 cents, Trev.
Josh(NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2012 at 11:30pm
Will electronic ignition help with tractors that don't won't to shut off (dieseling)?
Allis Express
'65 190XT, 37 B, '72 170, '83 8030, and the IH 560 was a mistake
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2012 at 5:15am
Let me know if my info is wrong. With points on a user tractor, you will have to change points once a year. With the new electronic ignition, no maintenance other than change spark plugs periodically?  Dave.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2012 at 6:22am
I've sold quite a few Pertronix E.I.'s, and can count on one hand how many times one of our customer's has had a problem. If the problem is the unit, Pertronix always comes through with a new replacement, or repairing the same unit. A couple things you have to be careful with and know about when equipping your Tractor with an E.I. module. First, watch when you charge your Battery with a Battery charger/booster. If you forget and leave the key on after finding a low Battery won't crank the engine over, you can blow the E.I. module out with the Battery charger. Always disconnect one cable off the Battery before putting the charger/booster on, and make sure the key is in the OFF position. This apply's to both 6 & 12V units. Also, on 6V units, when cranking the engine over, after releasing the starter rod the engine fires up, that is a normal condition. Reason why is the E.I. Module needs 4V min. to fire off. With most of the power going to the starter while its engaged, the E.I. in most cases will not fire until you let go of the starter rod. That split second gives the E.I. 4 or more volts to light off the engine. My B model does that everytime, but ole' Alice fires off everytime, even in the cold, cold weather. My IB is 12V, and as soon as I hit the starter rod, the engine fires right off, so this condition does not exist. Its only with the 6V version. The E.I. has been in ole Alice's Distributor for 11 years now and never had a failure. Lil' Al my IB is going on three years now with his E.I. I just feel that if the upgrades like this are available, and it helps the engine as well as cutting the maintenance down for me, well what the heck, its a no brainer.... Just my 2 cents...
KGood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KGood Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2012 at 8:30am
We have installed quite a few. When I did my uncles stock D17 I noticed the timing was the same before and after. I have had some trouble with brand new chineese rural king points in the past. Never had issue with pertronix yet. Like others said once you put one in you will want all to have them.
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2012 at 8:42am
no but a higher octane fuel or two steps colder sparkplug will.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2012 at 8:44am
If one wants a good electronic  ignition if not the best ignition a chevette hei from autozone $150 and you have one of the best. even petronixs best module is a four pin hei style module.
Edited by mlpankey - 13 Jan 2012 at 8:49am
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2012 at 11:04am
Once a year? I would think closer to 5 years on a moderately used tractor. I haven't changed points on any of my tractors or dads in 5 years except my WD45 just a few months ago for the first time in 22 years.
My 73 Ford F100 has 5,000 miles on a set of points and they still look great. I'm curious to see how long they last...no pitting or anything yet.
They don't wear out as fast as some people think.
I've seen a points tractor beside a pertronix tractor. I just don't see all these great things everybody is talking about. I guess I'm just beating a dead horse now...I'd rather spend my money on other things...the pertronix hasn't convinced me to buy.
Edited by 79fordblake - 13 Jan 2012 at 11:08am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2012 at 11:43am
If you got 22 years out of a set of points on your WD45 using it everyday without lifitng the cap, I wouldn't buy a Pertronix either. I'd have to find out who the mfr of those were, cause' they gotta' be outta business. The only set of points I had that went for 22 years is the set that's still in the box on my shelf for a Rolls-Canardly. (Not a popular set of points ya know.) Unless the Tractor sat for 21 years, I find that one hard to believe. But, stranger things happen I guess....
JRaymer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JRaymer Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2012 at 11:44am
What is the cost of installing it for each tractor or does it cost different for each model .
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2012 at 12:39pm
petronix coil and hall effect switch usually  120  chevette utozone remain hei 150.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2012 at 12:41pm
Well this was my Grandpa's tractor.. I don't know what brand the points were...but I do know they were in there for 22 years. The tractor plowed....disked...dug ponds with a pond scoop..pulled a combine and pulled thousands of tobacco wagons... it took many wagons full of grain to town also 14 miles away. Grandpa did everything with it.
Maybe it was just luck? I have no idea...I just know I'm not buying pertronix.....lol :)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2012 at 4:06pm
[QUOTE=79fordblake]Well this was my Grandpa's tractor.. I don't know what brand the points were...but I do know they were in there for 22 years. The tractor plowed....disked...dug ponds with a pond scoop..pulled a combine and pulled thousands of tobacco wagons... it took many wagons full of grain to town also 14 miles away. Grandpa did everything with it.
/QUOTE]
 O.K. save your money, but don't knock em' til you've tried one.  I have edited my post above, probably nothing in it to change your mind, but thats ok.
Post Options Post Options   Thanks (0) Thanks(0)   Quote NickT(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2012 at 5:38pm
I,m not sure if mine are petronix. Are they the only manufacturer? I got mine from Brillman Co. in West Va. They beat everybodys price and great service. That was before I knew about you Steve! I gave around $70each for all my sets. I have not replaced a single spark plug in 10 yrs., even on an M that smokes a little. P.S. I hate pts. and condensors
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2012 at 6:47pm
Electronic Ignition won't work after a EMP is set off and points will. Right? Mabe not.
Edited by Josh(NE) - 13 Jan 2012 at 6:47pm
Allis Express
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2012 at 12:05am
/QUOTE]
I said more than once I have had tractors side by side one with points and other with pertronix and the pertronix showed no improvements over good points. I wasn't really trying to knock them...I just think they are more hype than fact. I can't argue if they are bad or not but my experiences lead me to believe they don't help at all. I guess other people have seen big improvements.
This is just a guess but.......the people that are seeing big improvements means they had weak ignition systems and the extra spark is covering up worn wires cap..rotor...plugs...or maybe a poorley tuned carb.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2012 at 10:24am
So back to the beginning:   Jim's question was 'will it add horsepower'.
If you have a properly setup point/condenser system, tight distributor shaft, properly set timing and dwell, no wear on the contact points, no wear on the point cam, a good condenser, cap, and rotor, it will fire on time, every time, like it was originally designed... and regardless of what type of ignition system you compare, the power results will be the same- every cylinder, fires every time, on time.  So the answer is NO.
Now, if you have a distributor that is 50 years old, perhaps rebuilt 20 years ago, a little play in the shaft, contact points that sit for a while between runnings, a little wear on the point cam, and a condenser that's been on the engine for 12 years, some piston/liner wear, a little slop in the valve adjustments, a carbeurator that's got some play in the throttle shaft, then the answer is YES... but nothing more than what SHOULD have been there with the stock setup, in a brand-new condition.
So in that respect, everyone here is correct.  The answer is yes and no.
So what's the real answer here?
Electronic ignition of ANY type will naturally be superior, because it is devoid of the wear of the mechanical components, in critical locations, is integral to point-condenser design.  The long-term stability and reliability of an electronic trigger method IS superior, simply because it lacks moving parts, and is not subject to timing variations due to mechanical action and wear.  This is why you won't even find lawnmowers with contact points- they're all electronic trigger systems.
Wether or not it will survive an EMP isn't greatly relevant to horsepower development in the field, and wether or not you can stand alongside both while running and tell the difference isn't very relevant, but if you put BOTH under a series of tests, you'll find that, in all instances EXCEPT an EMP, that an engine equipped with point-condenser, when parked in a barn and ignored for five years, alongside an identical equipped with ANY brand of electronic trigger system, that the electronic will start sooner, and be more accurate, than the mechanical system, with NO maintenance to the trigger mechanism whatsoever... and without contact on the breaker cam, the distributor bushing doesn't wear out.
And from the final respect, the Pertronix kit has a distinct advantage over Pankey's HEI suggestion-  you can slap it in a stock distributor, and keep the point-condenser kit handy for the day you need to put it back in to get you home.
I'll advise, however, that if you choose to keep the point-condenser option, don't expect the contact points you buy today to be anywhere near as good as the ones that came stock, so buy about five kits.  The springs are made of lousy metal, the contact point material and plating suck, and the condensers are marginal in holding tolerance.  Good points and condensers are all but gone from the market now... the last half-dozen kits I've gotten were lucky to hold steady timing for more than a few weeks without having to take the cap off and clean the contacts, and it's a must after every long-term storage.  They just don't make 'em like they USED to.
And don't think I'm partial to old technology- I love brutal simplicity... I love the magneto in my '39 B, and I love the magnetos on my '42 Kohler, '43 Hobart, and '59 Consolodated generator sets... I wouldn't trade them, or the hand-start ability, for anything in the world.... and I truely fear the day that contact points become NLA for these mags.  The world's change to SMD electronics has made the availability of 'conventional' electronic components go way down compared to what once was... ignition condensers will soon join their ranks.
I love the Pertronix kit in my D17... and in my dad's '54 Century Resorter... and everything else I've put 'em in. They work as advertised, and when applied to ANY distributor, will outperform contact points in all categories of performance with exception of surviving EMPs and accidentally reversing the battery cables.
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2012 at 11:08am
Are they hard to install? Maybe I should switch my D17 over. How much are they? Do they work in 6 volt magneto systems for my WD?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2012 at 11:31am
I agree with most of what you said. I guess if there comes a time when I'll switch to the electronic but I still have good luck with points so I'm not going that route yet.
The fairly simple DuraSpark electronic ignition on my 79 F150 and Bronco is the most complicated system I have on anything. This is the whole reason I like things that are old. I see brand new vehicles littered all over the road...
I've been sorta off topic this whole time but I guess it worked out alright. I guess nobody is offended? If so I'm sorry....never meant to nor did I want to. I may be young but I was brought up in old ways and I am kind of set in them. I see all this old equipment/vehicles running around with minimal problems and then see all this new equipment/vehicles always broke down...doesn't give me much confidence in the stuff. I like computers and all that but I don't think the world should be consumed by them like they are now. Makes me think of this saying "America.....we use to make stuff here".
I have nothing more to add to points vs. electronic....lol...wow aren't you guys gonna be happy? :)
Sorry for dragging on everything guys. When I stand behind something I won't change my mind for nothing lol.
Edited by 79fordblake - 14 Jan 2012 at 11:32am
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2012 at 11:36am
Rolls Canardly Steve? I haven't heard that one in a long time! I had one once with the rare 4-50 air conditioner option.
I am still confident of this;
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2012 at 8:32pm
Pankey's Hei has several advantages over the petronix hall effect switch installed into a very small cap distributor.   1 can run 16 volts to coil and magnetic reluctor. 2 cap large enough air space to keep ionization from happening .3 terminal spacing far enough apart to keep high powered coils from cross arcing. 4 spacing allow more coil saturation time . 5 Hei is bullet proof .6 if u fubar wiring  24 dollar module and atube of heat sink paste and your back in buisness as quick as changing points with out the need of feeler gauges.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2012 at 10:14pm
Hey Luigi! You caught that one uh? I thought that one went over everybodys head.. LOL!
Steve@B&B
This page was generated in 0.199 seconds.
