Proper wheel mounting "B"
dad2many View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dad2many Quote  Post ReplyReply Direct Link To This Post Topic: Proper wheel mounting "B"
    Posted: 09 Jan 2012 at 9:13pm
OK, so I finally got the tire changed to the new rim and mounted back on my tractor. I'm not sure its right though. I have seen clamp blocks on the outside of the rim and the inside. I put them back on the inside as I found it and matches the other side. Also, I noticed that two of the bolts and blocks are eccentric. What is the proper way to mount and where are the eccentric clamps supposed to be located?
On another note, i found the previous owner had been running that hub loose and has worn out the hub splines. Anyone know what I can expect to pay for a good hub?
Thanks
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2012 at 9:21pm
there are guys on here that will give you advice on the hub. I believe that you remove some metal in the back of the hub to allow the wheel to slidr back further.
On the wheel mounting, 2 lugs are rigid and 2 are eccentrics. One of the  solid lugs gets engaged between the 2 blocks on the wheel to lock it, the second one gets mounted in the next hole position, so they are side by side. The eccentrics go into the remaining holes. I always put the 2 solid lugs at the top, and hang the rim on them, then slide the bottom into place and install the eccentrics. Bob
Post Options Post Options   Thanks (0) Thanks(0)   Quote dad2many Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2012 at 9:28pm
I was contemplating grinding the back down to allow more drawup but some of the splines are less than half the original.
 Its not a good feeling to hear that clunk on take off.
HagerAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2012 at 11:52pm
We just did a B with the same problem here.  I believe we paid $100 for a good wheel center and $50 or $60 for an axle.  Doesn't pay to do one without the other.
allisnut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisnut Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2012 at 7:01am
Hi What part of PA are you in I should have a good hub and a couple of centers for sale
let me know Thanks Phil
