C/CA Transmissions
Scott(SC) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott(SC) Quote  Post ReplyReply Direct Link To This Post Topic: C/CA Transmissions
    Posted: 09 Jan 2012 at 5:12pm
I know where there's a CA torque tube, tranny, axles, and pto housing. I was wondering if the torque tube and transmission will change out in my son's C. How about the pto housing and hydraulic?
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2012 at 6:50pm
They sure will. The only problem that you would have would be with the hydraulic pump. the C has a two piston pump and the CA has three. You would need a C PTO housing and pump or a CA PTO housing and pump.  If you use the CA PTO housing and pump you would need the pan type seat. You would not be able to mix and match the final drives. You would have to use both the same.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott(SC) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2012 at 7:22pm
We have C wheels, so C axles. The CA PTO is missing the pump. We have the C PTO and pump and we have a D12 PTO and pump. I guess the D12 hydraulic wouldn't fit under a bench seat.
This page was generated in 0.062 seconds.
