Sway blocks |
Andy NW Iowa
Topic: Sway blocksPosted: 09 Jan 2012 at 8:11am |
I bought these sway blocks on a farm sale and I'm wondering what tractor/s they come off of? Any educated guesses? The first one has a casting number of AM 5548 and also a FM is stamped under that. The second one has a casting number of AM 5382-1 and RH is stamped under that
Top view of the first one ![]() And the bottom, ![]() Top of the 2nd one notice the tab at the left of the picture ![]() and the bottom ![]() One or both of these could have come from a 210 or 220, but I have no way to cross the casting number I'd like to know a tractor they come from or a part number that the casting number crosses to. |
Travis(NE)
Joined: 24 Sep 2009 Location: Seward NE Points: 300 |
Posted: 09 Jan 2012 at 10:43am |
The top one is what I have on my D17IV and should be the same as 170-185.
The bottom one looks to me like a 210-220?
Andy NW Iowa
Posted: 09 Jan 2012 at 11:13am |
thanks Travis, Did you buy a sway block on ebay last week, because I sent one to Seward NE on Saturday.
Travis(NE)
Posted: 09 Jan 2012 at 12:25pm |
That would be me! Good to know my funds are going to another orange fan of this site.
nevans
Joined: 06 Dec 2011 Location: Red Bud. IL Points: 837 |
Posted: 09 Jan 2012 at 7:59pm |
The bottom one will work for a D21 210 AND 220 Niel
EPALLIS
Joined: 12 Sep 2009 Location: Illinois Points: 1163 |
Posted: 09 Jan 2012 at 9:10pm |
Sorry, to ask such a silly question, however what do you use a "sway block" for?? I've been around A-C for over 20 years and never heard this term. Thanks for any assistance and apologize for my ignorance. Going orange is going great!
Gregor
Joined: 11 Sep 2009 Location: Prague, Ne Points: 305 |
Posted: 09 Jan 2012 at 9:21pm |
Sway block are mounted on the inside of the lower 3 point arms to keep them from swaying back and forth or take the clearance away on how far the 3 point can move from side to side when hooked up to a 3 point implement. Some blocks mount on the arms or the drawbar hitch housing sides or both.
Travis(NE)
Posted: 09 Jan 2012 at 9:36pm |
The painted orange piece is a sway block in use on a series IV factory 3pt.
![]() The one in the picture should be the same as the very top picture.
EPALLIS
Posted: 09 Jan 2012 at 9:51pm |
Learn something new everyday and I really appreciate you going the extra mile to post the picture and show me. As usual a picture is worth a 1000 words. You're a good man Travis.
Thanks!!
Andy NW Iowa
Posted: 10 Jan 2012 at 4:23pm |
Thanks every body, I plan on posting these on Ebay next week, I also have a different set on now, differnt casting number, and a factory 3rd arm. Thanks
JoeO(CMO)
Joined: 11 Sep 2009 Location: Cent Missouri Points: 2696 |
Posted: 10 Jan 2012 at 5:05pm |
Travis, isn't that a little overkill on the drink holder? Oh, I see now, it's a cover for the hitch ball! LOL
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 34855 |
Posted: 27 May 2020 at 6:55am |
Used to be a Shallower block for Cat 1 attachments as on my 180, does anyone still repro those? Would seriously consider a buy of those. No blocks is WAY too loose, cat 2 blocks can be too wide and have to be pulled then back to wide swinging.
Edited by DMiller - 27 May 2020 at 6:55am |
Dave (NE)
Joined: 12 Sep 2009 Location: Eagle Nebraska Points: 2157 |
Posted: 27 May 2020 at 1:30pm |
Here is info from an earlier post: Wagner AG sales out of Doniphan NE phone #402-744-3831.
Do not argue with an idiot. He will drag you down to his level and beat you with experience. Mark Twain.
Oldwrench
Joined: 12 Jan 2020 Location: Northeast Points: 157 |
Posted: 28 May 2020 at 6:48am |
For whatever reason, Cat 1 sway blocks are not easy to find. All the new ones you can find on EBay are the Cat 2 ones. I use mostly Cat 1 implements on our D17 IV with factory 3 ph. I found one Cat 1 sway block years ago, then finally found another one last Oct, so it only took me probably 3 years to finally get both. Before I found this one, I had cut a block of hardwood out, which held up quite well for mowers and such. I had thought of just fabricating one from steel, or cutting off the excess steel on the Cat 2 ones readily available. EBay does seem to have them come up once in a while, but they are not easy to find for sure.
