WD belt pulley drive gear snap ring
maurice View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote maurice Quote  Post ReplyReply Direct Link To This Post Topic: WD belt pulley drive gear snap ring
    Posted: 07 Jan 2012 at 7:31pm
I have the WD engine bell housing off.  I am wanting to remove the belt pulley gear.  I see the snap ring does not have tab holes like modern snap rings.  Is there a proper way to remove the snap ring?  I have a picture that I can try to upload if needed.
stray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stray Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2012 at 8:21pm
There are a few types, a picture would help. But without it I would say a couple flat screwdirvers, preferrably ones that aren't your favorites, and a few bad words and a little time. Seriously there are a few differant type of snap ring pliers that I could be but will need to see what type to help.
1969 190XT series 3
Post Options Post Options   Thanks (0) Thanks(0)   Quote maurice Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2012 at 6:02am
Here is the picture if I post this right!
Post Options Post Options   Thanks (0) Thanks(0)   Quote maurice Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2012 at 6:05am
I'm sorry, looks like I over-sized the picture.  This is only 500kb.  The dust is where I hammered on pine wood blocks to drive the bell housing off.
DanD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanD Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2012 at 6:24am
That type of ring is called a lock ring as opposed to a snap ring.  You need a set of pliers like the first one shown in this link.  It's the best picture I could find, but these are readily available at Sears, auto parts stores, etc.
DanD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanD Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2012 at 6:27am
Here is the link again.http://www.mytoolstore.com/kd/kdspec20.html
Much better and messing with screwdrivers and having the tip break off and fly into your eye.  This type of ring has a lot of strength.
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2012 at 6:36am
I have 5 differant pliers in size with the flat ends for rings like these.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2012 at 11:30am
I have collected many types of snap ring pliers over the years.  I really like the "ratcheting" type that holds its position while removing the ring.
As said, the flat tip type is designed for this style snap ring.
Having said that, this type of snap ring is a "breeze" to get off with just a pair of screwdrivers, especially in this type of application!
Post Options Post Options   Thanks (0) Thanks(0)   Quote maurice Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2012 at 8:30am
I got the snap ring off!  Does the gear just lide off?  I assume there is a key, but I've gently but firmly pried but it has not budged.  If I need a special tool, does anyone have a picture link?
Thanks!
This page was generated in 0.922 seconds.
