hi-lo on d17 grinding
elalr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote elalr Quote  Post ReplyReply Direct Link To This Post Topic: hi-lo on d17 grinding
    Posted: 06 Jan 2012 at 9:39pm
i bought a 17 a while back and it finally made it to the top of the list. the biggest problem is it grinds when you pull it into low. it seems fine in high and nuetral. the other issues like it smoking like a train and multiple leaks, i think i can handle. any ideas where to start?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2012 at 9:45pm
Could have bearings out on reduction shafts. MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote elalr Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2012 at 5:27am
i also forgot to mention that it doesnt even try to move in low.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2012 at 7:08am
If it won't move and grinds in low side there is a bearing out on reduction shaft causing shaft to drop down from drive gear. MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote elalr Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2012 at 8:04am
ok thanks. i guess its time to dig deep into it. more than i wanted to do to it.
