WC Value
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Topic: WC Value
    Posted: 02 Jan 2012 at 6:53am
I resently found I believe is a allis wc that is in awesome shape  with all steel wheels. What would the value and rarety of these?
Can't fix stupid
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2012 at 7:49am
Realy need to know more  and a picture would help .
MBWisc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MBWisc Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2012 at 8:11am
The steel wheels may be worth as much or more than the tractor.
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2012 at 8:58am
What year? Is it styled(rounded sheet metal) or Unstyled(very squared)?
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2012 at 10:47am
A few years ago front steel, if original and in good shape would be worth more than the tractor. Probably still is. Not too many things rare about a WC. If it runs, might be worth $800-$1000 in good shape.
 Here is a tip toe steel wheeled unsyyled WC.
Here is the more common styled Wc but on rubber.
Edited by CTuckerNWIL - 02 Jan 2012 at 10:57am
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2012 at 11:31am
Charlie: Do you have any more pictures of that Industrial U that was behind the WC?  Dave.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2012 at 11:36am
No I don't Dave. I stole this picture from this forum at some time and never even kept track of who posted it. I just noticed this morning the Industrial front wheels on that U.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2012 at 11:48am
Dave let's keep this about WC'S,NOt U's.  LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2012 at 11:48am
I'm looking to buy an Unstyled on Steel right now too....its on steel because the beads rusted clear off and the tires have fallen off lol
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2012 at 11:58am
That picture with the U was taken at the Fulton County Fair Grounds looks like at the NTA Show.
Denis in MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Denis in MI Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2012 at 12:52pm
Yep, I think you're right that was in 2008 when they featured Allis Chalmers.
1938 B, 1945 B, 1941 IB, 1949 C, 2 1938 WCs, 3 1950 WDs, 1951 WD, 2 1955 WD45, 1957 D-14
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2012 at 7:17pm
 I don't believe Lewistown, Il has cement silos like that so I would guess it's not Fulton county Illinois fairgrounds. :)
 Would it be Ohio?
KenBWisc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KenBWisc Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2012 at 9:06am
Looks an earlier WC with steel steering wheel and radiator. Did it have base-mount mag and larger opening in the gas tank? The front pedestal and/or crank has been changed out. I'm restoring a steel steering wheel and long, single-piece crank now.
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2012 at 9:35am
 Would it be Ohio?
Yep! That be ohio.
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2012 at 6:41am
The WC looks very simular to the first picture. The older one. The rear wheels look a little different than that but thats definatly the body style. The sheet metal looks nearly perfect. paint a little faded but no rust from what i could tell.
Can't fix stupid
WC Dale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WC Dale Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2012 at 7:44am
AJ:
    From what little you have told us so far it sounds like it could be a good one to get ahold of. Tell us more. Does it run and is it drivable? Is the motor stuck? Has it been kept inside? What is the serial number on the rear end housing? If it is in the lower three thousands, this will lead to another series of questions about what parts of the tractor have been updated or not. Some pics from various angles will tell us most of this. Stay on top of this one.
