New"B" Battery Question
dpd128 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dpd128 Quote  Post ReplyReply Direct Link To This Post Topic: New"B" Battery Question
    Posted: 01 Jan 2012 at 7:15pm
I am new tractor owner/operator. I recently purchased a B series that worked well until I had to replace the battery. It was a 12v so I bought another 12v to replace it. Somewhere in the back of mind I remember the former owner saying something about the ground being positive. Does that sound right?
1. will this battery be ok?
2. will I connect the black cable to the + terminal on the battery?
I am just learning all about owning/using this tractor and want to keep it running well.
thanks!
Rick of HopeIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2012 at 7:39pm
standard setup for that tractor was ground positive with a 6 volt battery.   If the cable from starter post used to be to the battery negative before then it is still running that way.
If the battery does not seem to charge the generator may not be setup for 12 volt correctly.
