Gear lube in frt pedestal |
Post Reply ![]() |
Rog(NCWI) ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Aniwa.WI Points: 243 |
![]() ![]() ![]() ![]() ![]() Posted: 31 Dec 2011 at 9:44pm |
I changed the seals in the front steering pedestal on my WD Allis. I am looking for the number weight of gear lube that is in there and where can I get some? I have been told that it may be number 250 weight but have not found it anywhere.
R.W ![]() Orange Level ![]() Joined: 31 Dec 2010 Location: Swanton, OH Points: 2975 |
85-140 will work just fine. You can get it by the quart at napa.
m16ty ![]() Orange Level ![]() Joined: 28 Jan 2011 Location: TN Points: 1476 |
I run John Deere corn head grease in mine. It's a flow-able grease that tends not to leak as bad.
GregLawlerMinn ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Lawler, Mn Points: 1226 |
I use straight 140 wt in my tractors (both steering gear boxes). Available from NAPA
Currently have: 1 D14 and a D15S2. With new owners: 2Bs,9CAs,1WD,2 D12s,5D14s,3D15S2s, 2D17SIVs,D17D,1D19D;1 Unstyled WC |
wekracer ![]() Orange Level ![]() ![]() Joined: 13 Oct 2009 Location: Tebbetts, MO Points: 1590 |
Chain saw bar oil in our old CA
If I use straight 140 weight lube in the front end will that leak out?
Dave in il ![]() Orange Level ![]() ![]() Joined: 22 Sep 2009 Location: Manville Il Points: 1748 |
That will depend on how worn things are. Whith new seals I would doubt it, but if the surfaces the seals seat on are not true you could still have some leakage.
Jeff Z. NY ![]() Orange Level ![]() Joined: 11 Sep 2009 Points: 7326 |
Lucas sells it but I don't know if they sell in anything other than gallons. |
I Love Meatballs and Dumplings on Toast with Gravy and Rosemary and ??? {Open For Suggestions}
Post Reply ![]() |
