Wheel hub and wedge blocks
BiG210 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BiG210 Quote  Post ReplyReply Direct Link To This Post Topic: Wheel hub and wedge blocks
    Posted: 31 Dec 2011 at 1:31pm
Does the size of the hole in the center of the hub mater if you have the wedge blocks to fit the axel shaft.  le putting 7080 wheel hubs on 210 with 210 wedge blocks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2011 at 3:21pm
7080 wheel centers should work just fine as long as you use your 210/220 (3 5/8" inch axles) wedges.
