Manifold studs, washers and muffler bracket - WdD5
Brampton 02 gt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brampton 02 gt Quote  Post ReplyReply Direct Link To This Post Topic: Manifold studs, washers and muffler bracket - WdD5
    Posted: 30 Dec 2011 at 9:00pm
I am re-assembling my engine and wondering if aneed to use washers on the manifold studs.
I have lock nuts I bought from Agco, but the new manifold (aftermarket made in taiwan apparently!) looks like there are grooves or at least a small polished area for a flat washer.
I assume I should ude washers on the stud with the split casting?
Also does any one know what the proper muffler bracket is?  is it the three piece version - with a band clamp an one piece that connects to a head bolt (came with muffler and was on the tractor when i got it) or is it the single bracket which I also have?  I assume I must have to "massage" the end of the new muffler to fit into the new manifold.  Should the muffler rest on the muffler bracket bolt?
thanks.
I am getting close to starting the old girl.  I will post pics.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brampton 02 gt Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2011 at 8:59am
It is a WD45.  not a Wdd5
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2011 at 9:08am
I used brass nuts, stainless steel washers and copper based anti-sieze when I replaced the gaskets on the manifold on my WD.
It might sound like overkill, but I don't want to have any hassle if I ever have to take it apart again.
Orange Tractors View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Tractors Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2012 at 12:02am
I also painted the studs and the holes in the manifold with anti-seize when I replaced the manifold on my WD. The old studs were rusted to the manifod so bad that even if I could have gotten the nuts off, the manifold wouldn't slide over the studs.
Robert
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2012 at 9:20am
I forgot to say what Orange said; some of the studs go into the water jacket.
I recommend coating the threads that go into the head with Permatex #2 before installing them to assurethere is no leakage.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brampton 02 gt Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2012 at 11:07am
Robert
Good idea - I will do that as well. thnaks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brampton 02 gt Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2012 at 11:08am
did you guys use washers with the nuts?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Tractors Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2012 at 7:49pm
Yes, use washers. They help to spread the clamping force of the nut.
Robert
