wd-45 hyd's
Chris View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris Quote  Post ReplyReply Direct Link To This Post Topic: wd-45 hyd's
    Posted: 29 Dec 2011 at 2:07am
when i parkked it the hydralics worked fine , been sitting in a heated barn now thow won't raise but 2 inches and not changed anything. can anyone help?
 Thanks,
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2011 at 4:47am
Does it have enough oil?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2011 at 6:59am
Fill it up with oil should help. MACK
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2011 at 10:47pm
it's full of oil will only raise about 2 inches anyone have any ideas?
brianaf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote brianaf Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2011 at 10:59pm
Linkage may have slipped.
ctbowles58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2011 at 11:00pm
UNHOOK HYD. HOSE AT THE CYL. SEE IF YOU ARE GETTING OIL THERE . IF IT IS AN OLD HOSE IT COULD BE COLAPSING ON THE INSIDE.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2011 at 6:47am
Does the pump quit pumping or do you hear the pump trying to lift when it stops lifting?  MACK
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2011 at 7:00am
Where are you checking the oil?  Should be at the dipstick on left side of tourque housing across from hyd. pump. that is the fill pipe also. and as Mack asked can you here pump trying to raise lift?
Bull View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bull Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2011 at 9:15am
I had the same thing happen on my CA. One of the pump plungers was stuck in the compressed position.
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2011 at 12:36pm
I cant here pump running, linkage has not slipped. the arms will raise without anything hooked to them but slow. Any sugestions?
 Thanks,
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2011 at 3:32pm
Just for grins,screw the thumb screw down on frt of pump all the way in then back out and see what happens.It'll force the valves to move.Could have f/m sticking valves.
