AC Power Unit Trailer
GBACBFan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GBACBFan Quote  Post ReplyReply Direct Link To This Post Topic: AC Power Unit Trailer
    Posted: 26 Dec 2011 at 12:08pm
Since seeing Fred Wilke's 125 PU on a trailer built from an Allcrop tongue I have wanted to build one. I used rectangular tubing for the axle, used some old B spindles to get wheel bearings instead of bushings, and modified the tongue so it was square with the world instead of offset as they are on combines. I added a couple of cross supports to bolt the PU on with three bolts, and that was pretty much it.
Edited by GBACBFan - 26 Dec 2011 at 12:08pm
are genuine." - Mark Twain
Post Options Post Options   Thanks (0) Thanks(0)   Quote GBACBFan Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2011 at 12:09pm
Rear View
Post Options Post Options   Thanks (0) Thanks(0)   Quote GBACBFan Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2011 at 12:23pm
A pic with PU that needs prettying up mounted in place.
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2011 at 12:35pm
Nice!
mnoonan-NEWI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mnoonan-NEWI Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2011 at 12:35pm
That looks great Larry. We'll have to get that PU painted this summer.
AC CA, Ferguson TO-20, Ford NAA, M-M BG, AC #3 Mower, SC Plow, PH Digger, AC 720's with Ark 700 loader & Brantly Backhoe, "Mini B" w/flathead Ford V8
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2011 at 12:35pm
Are you taking orders?  :-)
Very nice!!!
Still in use:
daveingreenbay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote daveingreenbay Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2011 at 3:33pm
Wow!  That looks good, Larry.  It amazes me the work you get done between breakfast, lunch and supper.
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2011 at 3:37pm
That is so cool, except will it be stable if you're running something with the power unit?
D-17_Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2011 at 4:42pm
Looks real nice and I mean nothing negative in my critique, I just don't want to see anything or anyone hurt or damaged.
Aren't those low speed rims and tires? You said you replaced the bearings and thats a good start, but I bet those tires won't take much speed without coming apart and that could have bad results on the interstate on the way to a show if the narrow wheel base  flips it over. Also the 2 bolts in the hitch from the tongue is a weak joint. The light hitch isn't designed to support any applied load with only the top 2 bolts in place.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GBACBFan Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2011 at 5:10pm
I agree with the concern on driving this thing on the road. If you see this thing running down the highway behind a pick up it's because sombody stole it! Had that been my intent I would have made the axle wider, the PU lower, the tongue longer and used car spindles/wheels/tires. I do expect to pull it behind a tractor. Running it under load is a valid concern as well. If I would run anything with the PU I'd leave it hitched to the tractor. I actually don't know how it would react under load. The intent was to have a way to easily manuver a PU using as many AC parts as possible.
As for the hitch, there's a piece under the ball receiver shaped like an upside down "U" to give it strength that's 1/4" thick. (It's actually the top half of the excess 2"x3"x1/4" axle tubing that fit snugly inside, sandwiching the ball receiver between it and the 1/2" flat steel trailer hitch) It would never be strong enough without it. I also have an AC ball hitch as well that I may well use.
DaveinGreenBay, I sometimes surprise myself with what I get done between meals. I never miss a meal!
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2011 at 6:12pm
great job!! uh...can you build one for me to set my ole lady.....oooops...i mean my loving wife...on to?
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2011 at 6:29pm
That will be an attention getter at a show!!looks like you did a real nice job!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2011 at 9:54pm
I'm glad you have more thought into it than what it appeared  Don't judge a book by it's cover and such. As good as it looks I would hate to see anything negative happen to it or you.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2011 at 5:48am
I have great concerns about Safety.
How high can you lift the tongue before the whole thing suddenly flips over backwards?
The high 'centre of gravity' will be a problem.
I just see an accident waiting to happen !
Gary
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2011 at 7:05am
Nice work ,Now show the guy;s the to display P/U 's you got  from me .Did you make trailer's for them .
leoversteeg11 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote leoversteeg11 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2011 at 6:12pm
This one is mounted lower,but needs to be washed
