Distributor Drive Gear & Bearing Wd45
Brampton 02 gt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brampton 02 gt Quote  Post ReplyReply Direct Link To This Post Topic: Distributor Drive Gear & Bearing Wd45
    Posted: 25 Dec 2011 at 2:39pm
Does any one know where I could find a decent dist. drive gear (on the horizontal shaft - not on the vertical dist) and the bearing on the govenor weight flange?  The gear is $190 from Agco and the bearing is nla.  The gear I have is in rogh shape.
Gear part #70225078
bearing# 70215242
The dealer was kind enough to cross the bearing to NNice 5137-2  IS THAT SOMETHING i CAN GET FROM A BEARING SHOP?
Thanks!
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2011 at 4:25pm
    call 1-574-342-4545 tue morn   can help
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2011 at 11:06am
If the gear on the drive is wiped out, so is the Distributor's main shaft gear being they mesh together. Its better that you change the two as a unit or you'll wipe the drive gear out again. If Norm can't help ya, we have govenor drive assy's rebuilt/exchange for $150. Drop us a line if interested, I can send ya a pic.  customcircuits@gmail.com
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brampton 02 gt Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2011 at 11:42am
Thanks.  I think the dist driven gear is ok.  It is likely rust that killed my drive gear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2011 at 7:31pm
  we have the gear an bearing in stock  can ship     visa-master cards -discover
    call 1-800-254-3116
