Turf Tires
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Topic: Turf Tires
    Posted: 25 Dec 2011 at 7:21am
On a C. I have regular tractor tires now, size 9-24's and have a chance to get some 16.9-24 turf tires.  Will these fit on my rims?  Or are they just too wide?  I use it for just cutting grass right now.
Thanks
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2011 at 7:57am
They are a bit on the wide side for 9" rims. They would be shaped like donuts. And they would weight half what the C does.
Gerald J.
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2011 at 7:58am
I would probably want to go with at least 12" wide rims when mounting 16.9 tires. They are going to be a bit oversize for a C. I have a set of 13.6 24 AG tites  on 11'' rims on a CA and they look OK. Some of the wide 24'' compact Japanese tractor rims will bolt up on AC B/C wheel centers.  Look for either the 4 loop or the Z bar mounts with 19 3/4 bolt center spacing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2011 at 11:11am
Ted, don't know what you can handle or have the tools for, but you could always take the rims you got and take a torch or plasma cutter and split the rims and then get some flat stock and widen them out.   I have a set here that I want to do that way and my brother has a plasma cutter to do the splitting part.   I have used it once on a small rim and it does a nice job and makes a pretty clean cut.   Just make sure that you add space the right way keeping in mind how much the rim will offset being wider.   Good luck and Merry Christmas.
