301 head interchange
schwanman66 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote schwanman66 Quote  Post ReplyReply Direct Link To This Post Topic: 301 head interchange
    Posted: 24 Dec 2011 at 9:11am
Will a cylinder head off a 7020 fit a 1970 190xt without problems?  what are the differences between the two?
Brent
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2011 at 9:24am
will fit, but they are very different. Injectors/holes are different with 7020 head having copper tubes, and having tapered injector tip nuts using no sealing washer. Also the water passages in the front are different.
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2011 at 9:27am
We put a 190 head on a M2 Gleaner, the old head had the copper tubes and a crack.  Like Ed said had to change injector tips, otherwise it worked good.
Post Options Post Options   Thanks (0) Thanks(0)   Quote schwanman66 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2011 at 9:31am
sounds like more extra work then needed.  There's one on eBay needing rebuilt for $100+shipping currently.  Same guy has a water pump and oil cooler off a 7020 as well as a ray-jay turbo off a 220.  used allis parts
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2011 at 9:16pm
I would not want to go backward by putting a copper sleeved on a 190XT since the old head is the best.
 I have some 190XT heads that I would take 75.00 each. You can take your pick.
  MACK
