wd45 wide front
steve(oh) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(oh) Quote  Post ReplyReply Direct Link To This Post Topic: wd45 wide front
    Posted: 24 Dec 2011 at 8:29am
How do I tell the difference between a factory wide front off a wd45 and a Schwartz wide front?  We have two different wd's with wide fronts the cranks come out in different locations on the front.  Also the plate on top of one is round and the other one has a square plate.  I did not know if one of them was a schwartz or if this was just difference in design between the years.   Thanks Steve
When your working on something how does it always seem that merphy's law come into affect?
Wide open, Untill you see God. Then Brake
acwdwcman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acwdwcman Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2011 at 8:37am
this is factory
this is schwartz
wd with a freeman model 90 trip loader, wd45, 38 unstylled wc, b 10 garden tractor and 2-14 ac trip plow. grandpa has a 56 wd45. wd. allis chalmers snap coupler blade and 3 bottom snap coupler plow
Post Options Post Options   Thanks (0) Thanks(0)   Quote acwdwcman Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2011 at 8:40am
but you might have the 4 bolt wide front if its on a wd45. the factory one in the picture is a 3 bolt. but they look the same exept there is 3 bolts to bolt them on instead of 4
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2011 at 8:55am
A Schwartz wide front has a round axle tube, the Allis Chalmers wide fronts have square tubes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(oh) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2011 at 2:07pm
Thanks for the help
