WD45 Hard to get in Gear
bdallman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bdallman Quote  Post ReplyReply Direct Link To This Post Topic: WD45 Hard to get in Gear
    Posted: 20 Dec 2011 at 11:37pm
Alright so I am new to working on my WD45. I just got it a couple of months ago. It's always been a little tricky to get in gear especially 2nd and 3rd. When i have the clutch completely pressed it wont go into gear (most of the time). If i float the clutch to about half way they will click right in. No grinding or anything. 3rd is definetly the hardest to go into gear.
Also if i am driving along in 2nd i can push in the clutch and shift to 3rd while it's still moving and it doesnt grind or skip a beat. same goes for 1st to 2nd (Basically shifting it like a manual truck)
I am talking about the foot clutch on everything of course. Is there anything i need to check on it or is this normal for a 45. THe clutch doesnt slip and it doesn't try to walk when it's in gear and the clutch is pressed in.
thanks
1954 CA, 1952 WD with Freeman Loader,1955 WD45, 1963 D19 Gas, 1984 620H, 1980’s AC Forklift, 66 All Crop Harvester, White Top Roto Baler, Misc S.C. Equip and AC Collectibles.
kev/ont View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kev/ont Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2011 at 6:43am
that is standard for any non syncro manual transmission. You have to float the clutch to line the gears up so you can shift it. No worries, drive on.
Chad(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2011 at 6:55am
Kevin is right on. Also, I'd recomend NOT shifting gears while on the fly....good way to create problems for yourself.
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2011 at 6:56am
As Kev said be thankfull it shifts that way, it means whoever owned it before took care of it and your shifting collars and gears have nice sqaure dogs on them.  I just had to fix one that easily went into 2nd and 3rd,, and easily popped right back out under load.
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2011 at 7:01am
Shift mine from 2nd to 3rd like that all the time. Never grind. downshifting you need to stop for though.
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
RickinNH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RickinNH Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2011 at 7:53am
My understanding of late Wd and WD45 transmission were built with helical cut gears. It was AC try at making a synchro-mesh tranny. It would never be confused with a Muncie. That said until you have gone through the problems that occur in the transmission top you may think it is indestructible. It is not. Treat that shifter with respect or you could find yourself out in the field with the shifter out of the top and you trying to look into the hole with a flashlite.
Longmeadow Farm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Longmeadow Farm Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2011 at 11:25am
I have an AC 175 that does the same thing. The transmission is a constant mesh, collar shift arramngement ..much like the wd-45. I bought the tractor new in 1980 and typically put the power driector in neutral when shifting gears... when shifting like this the "collars" move around freely... and shifting into 2 or 3 from reverse is uneventful... just requires another step... but then I don't grind the collars or have to wait for things to line up while releasing the foot clutch.
Josh Day View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh Day Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2011 at 3:48pm
So can you shift on the go or not?I've heard both sides, it's ok to shift on the go, and never do it. I did it on my CA once from 2 to 3 at low idle, and it worked fine and kept right on going. But I dont want to do any thing to tear it up. And also can you shift using the hand clutch on a WD? Thanks
Edited by Josh Day - 21 Dec 2011 at 3:50pm
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2011 at 3:57pm
   Can you...
   Shift on the go ?           Yes.
   Shift with hand clutch ?  Yes.
   Should you...
   Shift on the go ?            No.
   Shift with hand clutch ?   No.
http://www.rumelyallis.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh Day Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2011 at 4:01pm
Thanks Rfdeere, thats what I was wondering.
What will it do to the trans if I do?
Edited by Josh Day - 21 Dec 2011 at 4:02pm
Goose View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Goose Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2011 at 4:01pm
When I have a problem shifting into another gear, I find it helpful to throw out the hand clutch AND use the foot clutch. It'll go in gear a little easier without grinding that way.
m16ty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote m16ty Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2011 at 4:42pm
I have always shifted with the hand clutch when needed. Like when you are bushhogging and need to back up. You won't grind a gear if done right and I've done this all my life. Never had a tractor that would jump out of gear either. If you don't shift with the hand clutch in certain situations, you've just eliminated your live power. You might as well have a M farmall or 8n Ford.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bdallman Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2011 at 9:04pm
Thanks guys i appreciate all the help. I was just making sure she was ok. I really like to take care of my 45 since it's so near and dear to me i always try to fix something thats wrong fast so it doesn't compound into something much worse. I will def not shift on the fly anymore. I never have before... i was just trying to get in gear and it worked so thats why i started doing it. not anymore though!!!!
This page was generated in 0.046 seconds.
