WANTED: AC WD Rear Rims
John Elwell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John Elwell Quote  Post ReplyReply Direct Link To This Post Topic: WANTED: AC WD Rear Rims
    Posted: 17 Dec 2011 at 5:10pm
I am looking for 4 rear rims for an AC WD. They can be the adjustable or the bolt on kind. several weeks ago a person on this site from I think Ohio or Illinois, indicated that he had some, but I lost the contact information. If you are reading this, then I am still very interested.
Also, my two WDs currently have adjustable rims...will the non-adjustable rims fit the hubs of the tractor?
Thanks,
John
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2011 at 5:51pm
There were several different combines that used a stamped dish rim(non adjustable) that have the same bolt pattern.New power adjust rims are $400+ each last I saw. I guess if you had new PAW rims and new tires you could have $2k in the tractor if the rest was given to ya. :(
Post Options Post Options   Thanks (0) Thanks(0)   Quote John Elwell Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2011 at 6:09pm
I know...that is why I am looking and hoping to find used ones that are still in fairly good condition...
John
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2011 at 6:57pm
I put new rims from OK tractor and New tires and tubes from a local dealer on last year they were $1900.00. After taking the tires off my good lookin rims they wern't that good.They had been repaired. looked good on the outside.  after scraping the stuck tube off the rim. there were rust pin holes that could not be seen with the tire on. I put new tires and tubes on every tractor in the last 30 years shortly after getting them. ocne you put new on you shouldn't have to mess with them again.
This page was generated in 0.079 seconds.
