28"spoke tractor rims.
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Topic: 28"spoke tractor rims.
    Posted: 17 Dec 2011 at 5:18am
A pair of 28" spoke tractor rims on Toledo Craiglist,$80,not mine.
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2011 at 8:16am
I wonder what they came off of? Usually 28" spokes are from a Farmall but these don't have enough spokes for that.
GBACBFan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GBACBFan Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2011 at 8:52am
The rim portion also seems very "shallow" at the bead area from the standard spoked rim. I have the same question Lonnie has as to what they came off of. I can't even picture being able to mount tires on those wheels.
are genuine." - Mark Twain
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2011 at 9:00am
I can't tell for sure from the picture but it looks like the rims are welded on to the spokes. I don't think they are the original rims for the spokes and centers. It don't look like they would be any good for mounting tires on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2011 at 3:39pm
I remember seeing wheels like that with almost flat type rubber tires on them.  The original center is gone, and a regular wheel welded in its place.  The flat type rubber tires that I remember were only about 2 1/2 to 3" high and about 5" wide.  They were solid tires, no inner tube. Don't remember what they were on though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2011 at 3:45pm
Ted, I blew the picture up and it looks like the spokes are riveted in the hub like the F&H spoked wheels.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2011 at 6:21pm
Yeah, it does look that way.  Kinda hard to tell but I think so too.  Would still bet on the flat type tire though.
steelwheelAcjim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steelwheelAcjim Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2011 at 6:37pm
I inquired through e-mail if there were any casting marks or numbers on them. The owner replied that there were not any that he could see.
I think they are front steerable wheels off of a manure spreader. The bolt pattern is what's baffleing me! I can't come up with a tractor that they would fit.
Pre-WW2 A-C tractors on steel wheels...because I'm too cheap to buy tires!
This page was generated in 0.043 seconds.
