1929 E 20 35
farmboycitygirl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmboycitygirl Quote  Post ReplyReply Direct Link To This Post Topic: 1929 E 20 35
    Posted: 15 Dec 2011 at 4:00pm
Anyone know where I can get a float needle for a 29 E?
split51 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote split51 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2011 at 4:19pm
 Try Norm Meinert
1929 20-35 sn17662
B1 w/snow blade
B10 w/sickle mower
B110 w/mower deck
B110 w/tiller
B112 w/grader blade
B210 w/plo
Darrell G (MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darrell G (MN) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2011 at 5:42pm
What Carb do you have?
Tricky Dickie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tricky Dickie Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2011 at 3:51am
Should be a Kingston L
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmboycitygirl Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2011 at 10:18am
Have no idea on the carb - it is all brass except for the float bowl.  Tractor used to set outside and got water in the bowl and froze.  Once froze the float was ruined.  Larry Swenson found me a float but somehow the needle was misplaced.
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2011 at 10:36am
That's a Kingston L by your description. Norm Meinert, as stated above should be able to help you out.
Norm Meinert View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Norm Meinert Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2011 at 10:31pm
i have carb kits, new brass floats, new bowls, throttle and choke shaft, gaskets. can sell individual parts such as needle valve. will rebuild  any ac carb.  call 1-815-865-5372 or www.normsactractors.com
