Tisco Paint
bincitybandit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bincitybandit Quote  Post ReplyReply Direct Link To This Post Topic: Tisco Paint
    Posted: 14 Dec 2011 at 11:23pm
Ya, I know it is not the greatest quality, but I bought some online for my current restoration of a D17, which is not to be a show tractor, just want it look orange and have a shine.
I see on the directions that it says to thin 8-1 with mineral spirits and drying time is somenthing obsurd like 10 hours.
So my question is can I thin this stuff at a 2-1 or 3-1 ratio with something like a Nason 441-21 Medium Reducer and still get decent results?
ALLIS: B, WC, G, G, D10, D12, D14, D14(NF), D15, D17, D17(NF), D19, D21, D21
MINNEAPOLIS MOLINE: U, U, U(NF), GB
JOHN DEERE: L
FORD: 871 Select-O-Speed
CASE: 600 Combine
ctbowles58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2011 at 11:33pm
use VMP NAPTHA THINNER it will dry faster also you might want to use a hardner.just thin it until it looks right.
Roddo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roddo Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2011 at 6:39am
I think thats the same crap paint I bought to paint my plow.  It worked well enough, but if your tractor stays in the sun for any amount of time it will be bleached and faded in 2 years.
allis6080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis6080 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2011 at 7:04am
i have used it before and had no trouble with it. painted some allis and IH tractors. make sure u use med. reducer other wise it will dull the shine and we also used hardner if i remember right 4 part paint 2 part reducer 1 part hardner.if its going to be just a work tractor then it will work just fine!!!! I know valspar paint from tractor supply WILL fade and look like crap. i have seen a few JD's that were painted with valspar and they turned oliver green.
Edited by allis6080 - 15 Dec 2011 at 7:07am
6060 s\n 5016
1947 JD B
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2011 at 7:24am
Not much differrent than any other low priced paint.  We have some stuff that is approching ten years old with that type paint and it still looks working class decent but it stays inside. Sitting outside it wil look like an orange creamsickle in a couple years or less.  As for the reducer if you want to have to most miserable painting experiance you can imagine use what they reccomend, mineral spirits. I have used my Omni/PPG Urethane reducers with excellent results and a fellow up the road uses plain ole cheapo laquer (never could spell that word?) thinner.
Our 38WC and a 8-9 year old paint job with farm/fleet paint, PPG reducer and a bit of valspar hardner.
Edited by Butch(OH) - 15 Dec 2011 at 8:11am
Don(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2011 at 7:29am
Awesome picture butch.
Can I ask this then?
Whats the difference between the new valspar "Restoration" series paint, and the ol' valspar implement paint at TSC?
Is it really that much better? Think its 40-50 bucks a gallon.
Galatians 5:22-24
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis6080 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2011 at 7:31am
if i remember right i think tisco paint is made by the same company that makes the paint for agco but i could be wrong though.
6060 s\n 5016
1947 JD B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2011 at 8:03am
Realy doesnt make any differance whos name is on the can if it is enamel and priced cheaply, like less than $40 per gallon it is Alkyd enamel and has the same traits as all other of same basic chemistry.  The restoration series paint mentioned I have never used except I spray bombed a mower deck. To tell you the truth I see little differance between it and regular "implement" paint per above.
Sorry about the gigantic picture above, I forget to check the size when posting and know have it thoroughly screwed up trying to edit it and cannot delete it.
Edited by Butch(OH) - 15 Dec 2011 at 8:15am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2011 at 9:17am
Thanks butch, I kinda wondered if the paint was the same, in a different can.
Galatians 5:22-24
Jeff B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff B Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2011 at 12:54pm
There is nothing wrong with Tisco paint. This tractor was painted using it.
SenseiCrusher View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SenseiCrusher Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2011 at 1:01pm
I have used the Tisco paint like Jeff, it went on very thin and took over night in warm weather to dry properly. Did 4 coats minimum and the results are good for a working tractor, I am happy. I didn't have to block sand or do any extra steps.
BrianC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2011 at 7:25pm
I have to paint my C.
I don't want it to fade in two years if left in the sun.
If true that the Alkyd oil enamels fade in two years I don't want that.
And they are slow to dry, could take a week to paint.
How do the Acrylic enamels hold up?
How about the 2 part single stage urethanes?
And the two stage basecoat-clearcoat urethanes?
What if I put a urethane clearcoat on top of the two year paint?
Are the orange colors prone to fade? I see a lot of lousy looking Kubotas.
I haven't been able to find real data. Really frustrating. Some manufactures
make all of the above, you would think they would have full test results
online. Instead we got the likes of Valspar who can't even tell you what shade
of Persian Orange they are aiming for.
The Krylon 1820 rattle can, I did a test panel. I went on perfect first shot.
It dried FAST. I look on Krylon web site, cannot find a mention of what type of paint
it is. So other than being fast and easy and mostly the correct color (I would eyball it as
a tad dark in shade), who knows if the first drop of gas will wipe it off, or if it will
look like a Creamcicle in two years. The MSDS shows alot of VOC's in there.
Merry Christmas.
GlenninPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2011 at 9:10am
I took pity on you Butch.....
Good judgment comes from experience. Experience comes from bad judgment.
From listening comes wisdom and from speaking comes repentance.
Wise men learn more from fools than fools from the wise.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2011 at 9:11am
Merry Christmas.
The Build-a-B was painted mostly with Krylon 1820. How is it holding up?
Gordy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gordy Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2011 at 9:29am
I have used that type paint with xylene thinner and hardener with good results dries fast can go with another coat in 30 minutes I have a 45 that was painted 10 years ago still looks good
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2011 at 9:55am
I'm using Valspar Refinish 999 series basecoat and then the clearcoat.
For my basecoat you must apply the clear within 24 hours or you will need to rescuff the basecoat and re-shoot the base, then apply the clear within 24 hours.
That said I'm thinking the clear will peal off if you apply it over 2 year old paint.  May look good for a short time and then start coming off.
Edited by Stan IL&TN - 16 Dec 2011 at 11:54am
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2011 at 7:08pm
I have a WD that was painted in cheaper tractor paint...like tisco or valspar. If left outside they will fade....mine faded to a orange pink. Then they need repaited...I have tried to some success in using a rubbing compound polish to restore the color... I think if you keep the tractor inside it will be ok ...
By the way, what type of paint did Allis Chalmers use when they painted their tractors back in the 40's and 50's?
PASTOR MIKE
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2011 at 10:39pm
My neighbor has a nice muscle car. The clear coat is peeling off in some areas.
He says they took too long to do some fancy pin striping. Then applied the clear coat
as the window of opportunity closed.
But I was wondering if I used $35 per gallon alkyd oil paint (maybe with hardener).
Then applied a clear coat if such exists for this paint, would my paint last
way longer?  Does the proper clear coat make all paint jobs last longer?
equipmentcolor.com sells AIC (Sherwin Williams)  acrylic enamel and urethane paints.
They have a PO#1 and PO#2 mix in both types of paint. Has anyone used this paint?
amac View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote amac Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2011 at 8:29am
A 2 component single stage urethane is your best bet. You can spill gas and it won't hurt the paint at all. It will also give you 10+ years without fading. The gloss is excellent and if you want more you can add 10-40% clearcoat in the paint with your last coat. Yes its expensive but as a comparison you will have to re-do a tractor 3-4 times with the tisco or TSC valspar to be comparable after 10 years. It all depends on how you want the tractor to look over the next few years.
This page was generated in 0.336 seconds.
