D17 engine ?'s
79fordblake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Topic: D17 engine ?'s
    Posted: 13 Dec 2011 at 5:03pm
Got started on the neighbors D17 today giving it a full tune up. Started straightening the wiring out some. I wrote down the serial number then looked it up about 5 minutes ago when I got home. Numbers show that it is a 1960 D17.
This got me to wondering did the D17 have the full flow oil system in 1960? If not then the engine has been changed b/c this one has full flow. Engine number is 17-2300-M
Thanks for any help.
Edited by 79fordblake - 13 Dec 2011 at 5:07pm
DanD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanD Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2011 at 5:06pm
That is a very low engine serial number that I would think should have the bypass system on it.  Please post a picture!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2011 at 5:40pm
Full-flow oiling system on gasoline engines happened at sn 24001, which was later 1959.......engine number must be 23000 not 2300.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2011 at 6:08pm
I looked more than once it says 17-2300-M
Ill look again tomorrow I guess to make sure.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2011 at 6:20pm
What is the chassis number ???
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2011 at 6:25pm
28229
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2011 at 7:02pm
By the time your tractor was built, there were already 21,362 gas D17's built. I think the engine serial numbers began 17-1001 and went up from there. so your eng serial number should be at least 22,362....remember, other D17 engines were being built for other uses all while they were being put in the tractors.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2011 at 7:11pm
So if I look again tomorrow and the number actually is 2300.....the engine was originally in something else?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2011 at 7:35pm
NO......17-2300-M would have to be old block oiling system, which is a different block. Now, I suppose it could be an old block that someone (like myself) could have converted over to Full-Flow oiling, but if that was the case, where the lower oil line comes out of the block, there would be a Hex plug (1 1/8" wrench size) that has been drilled-tapped-threaded to accept the 90 degree brass elbow. If that's the case it isn't the original block if it has this hex plug.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2011 at 8:00pm
Ok...I am going to get a picture tomorrow and check the number again and will post back.
DanD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanD Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2011 at 9:02pm
Here is a link to a video if the engine in my dad's Gleaner E.  It is of course a 226 engine with the full flow system on it.  If you pause the video at the 26 second mark, you get a good view of the oil line set up.  You can see the two large oil tubes coming from the block up to the oil filter (the lower tube is oily and hard to see).  On a bypass oil system, there is only one small tube and there will be a large bolt head on the side of the block near the dipstick which is where you can access the oil pressure relief valve.  In the bypass system, the relief valve is integral with the oil pump.
The two tubes on the full flow system are for oil to flow to the filter and then back to the engine internals.  On the bypass system, the tube is for a portion of the oil to flow to the filter and that oil then flows back to the sump through the bracket holding the filter and through a hole in the block.
[TUBE]4u1s7ZD5ZS0&list=UU1pJAnFUOcOzMm079TJdBuQ&feature=plcp[/TUBE]
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2011 at 11:14pm
Well you guys can have a good laugh over this one.....heres a tip don't try to read numbers in a dark barn. I pulled it outside into the light..engine number is 17-23800-M so it looks like all is normal here. :)
