Dissapointment of the day
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Topic: Dissapointment of the day
    Posted: 08 Dec 2011 at 10:32pm
I have had a WC engine block stuck in the corner that I thought was a really good block, as no freeze crack, good crank, sleeves. I have been sweeping around it for several years.Today I decided to take the crank out to check it out really good to use in my WF, the rear main bolt holes are both cracked and on one side a chunck ready to fall out. Goes to show, you never know until you look them over with a magnifying glass. Now it looks like I am searching for another 37 year block. I do have a good WD45 block I would trade for one. Dave
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2011 at 4:07am
Another dissapointment is when you spend $45,000.00 on a racing engine and the engine builder tells you it comes with no warranty and no guarantee that it will even run and it may even blow up as soon as you start it.
I Love Meatballs and Dumplings on Toast with Gravy and Rosemary and ??? {Open For Suggestions}
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2011 at 5:51am
Aren't all racing engines sold that way?
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2011 at 5:52am
Dave, I have a good early WC engine block with the head studs still in it,I think,along with the sleeves. There are no cracks between the sleeves,in the lower webbing or on the side of the engine. I actually have two,so come and get one.  Rick
SenseiCrusher View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SenseiCrusher Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2011 at 9:03am
Getting married comes with no warranty and it will cost you many times the cost of a racing engine whether it goes boom or runs for life.
TerryMO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TerryMO Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2011 at 3:14pm
Dave,  I bought a Wc with a corn picker I do not want the WC. I will check on the year if you are interested. Lel me know.   Terry
Dipstick In View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dipstick In Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2011 at 3:26pm
I can understand. I have my dad's 37 WC that he bought new and then he died in 1941 when I was 9 months old. I was gonna restore it but the block had a patch cracked out of the side. I was talking to my brother a year ago and found that it wasn't the original engine anyway because our cousin started it and ran it with no antifreeze in it and burnt the motor up. So I guess that frees me up to using another block anyway.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2011 at 4:33pm
Yes, and that's why it's a dissapointment.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2011 at 4:35pm
That's why you have to hide a little of what you have.
That's called marriage insurance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2011 at 4:36pm
Don't think she isn't.
She is.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2011 at 4:40pm
 I've never been known to stir the pot, but what does this have to do with Allis Farm Equipment. ;)
Edited by CTuckerNWIL - 09 Dec 2011 at 4:41pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2011 at 8:55pm
Thanks guys, I have found a couple Blocks now and I had also needed one for the Grandsons tractor, now that is taken care of also.  Dave.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2011 at 6:33am
Nothing like many other posts in this section.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2011 at 6:38am
If you can't beat em, join em
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2011 at 9:52am
From what I've seen, it'd be most accurate to say that it was typical of Jeff's behaviour to do so.
His answer SHOULD have been "Nothing like MY OTHER POSTS in ANY section."
Edited by DaveKamp - 11 Dec 2011 at 9:54am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2011 at 9:56am
David- that sounds like a really strange failure.  Any thoughts on what would have caused it to get damaged that way?
Brian S(NY) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian S(NY) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2011 at 10:05am
Uh .. I seem to remember hearing about AC and their racing tractor. Lets hope those engines didnt cost 45,000.00
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2011 at 10:05am
From what I've seen, it'd be most accurate to say that it was typical of Jeff's behaviour to do so.His answer SHOULD have been "Nothing like MY OTHER POSTS in ANY section."
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2011 at 10:09am
It just to keep you guys busy posting stupid replies.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2011 at 10:24am
Don't go bashing my behaviour.
I have a behaviour disorder.
PMS
Permanent Mental Syndrome
Translation:
I'm Nuts!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2011 at 10:27am
PS:
You guys shouldn't get off topic.
What's this got to do with racing engines???
