Springs for a trip bottom plow
Don(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Topic: Springs for a trip bottom plow
    Posted: 07 Dec 2011 at 4:52am
Got a question, has anyone ever replaced the springs on a trip bottom plow, with a heavier than stock, spring?
The reason I ask, is that the 4 bottom SC I am looking at; the owner said it trips occasionally. I talked with my grandpa, and he used to own one years ago. His comment is that it would trip, when there was nothing to trip it! Said one bottom gave him problems about every 30 feet. He asked the local allis dealer what to do about it because the plow was only 2 years old. There response was to change the springs.
So I am wondering now, that when I replace the springs, I should go with a heavier than normal spring? Anyone done this?
Thanks!
Edited by Don(MI) - 07 Dec 2011 at 7:16am
Galatians 5:22-24
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2011 at 4:55am
On a 2000 monoframe if you put a washer under the spring acording to the book it adds about 500# more force to trip the bottom. Maybe this works on the older plows.
Edited by Lonn - 07 Dec 2011 at 4:55am
Wink
I am a Russian Bot
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2011 at 6:54am
Been just a bit since I have looked at a series 80 but isn't there an adjustment for the spring? Stop gap fix is factory installed for you. Look down the side of the beam abovethe pivot bolt there is a small hole I think 3/8, where you can install a temporary shear bolt.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2011 at 7:11am
Good idea Lonn, thanks.
Butch, I don't have the plow yet. But I do remember seeing the smaller 3/8" hole you were talking about. I thought it could be where a shear bolt would be put in place, but didn't understand why. Looking forward to bringing it home, to work on it.
Galatians 5:22-24
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2011 at 12:57pm
Don, is it a fully mounted SC plow or semi-mounted (with the tail wheel)?  If it's semi-mounted, I'd love to see some pictures.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2011 at 1:30pm
I think its semi mounted.
It has a non-hyraulic tailwheel, that is a depth stop.
Galatians 5:22-24
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2011 at 1:33pm
If someone could show me the differance with pictures, between fully mounted and semi mounted SC plows, I would appreciate it.
Edited by Don(MI) - 07 Dec 2011 at 2:10pm
Galatians 5:22-24
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2011 at 2:54pm
Don, there isn't much difference other than the beaming screw used.  This plow has the beaming screw that is intended to have a stop on the tail end.  The lift arms lift the front of the plow and the hydraulic cylinder (missing in picture) raises the rear of the plow.   BTW, this is a #73 plow purchased new from Muller Implement Co. sometime in the mid-50's.
This second and third pictures show a little more detail on the beaming screw.
This last picture is the same plow but with a different beaming screw (and newer, donor bottoms).  I essentially turned the semi-mounted plow into a mounted plow.  The tailwheel is just along for the ride now.
I'd like to find somehow to "unfreeze" the threads, etc. on the original beaming screw and turn it back into a semi-mounted plow.  If anyone has a beaming screw of this type, I'd be interested.
Edited by Brian F(IL) - 07 Dec 2011 at 2:57pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2011 at 3:00pm
I guess its semi mounted then.
Galatians 5:22-24
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2011 at 4:54pm
Brian, the one I am looking at, looks alot like this one...
The one I am looking at, are 16" trip bottoms, and has a gauge wheel that is a depth stop only, non-hydraulic, no cylinder. Now whether thats fully mounted or not, I guess I still don't know! lol
Edited by Don(MI) - 07 Dec 2011 at 5:03pm
Galatians 5:22-24
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2011 at 5:10pm
   Don, if the gauge wheel is on the left side, beside the rear bottom, it would be a fully mounted plow. Here is a picture of a #74 :
Edited by Rfdeere - 07 Dec 2011 at 5:25pm
http://www.rumelyallis.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2011 at 6:27pm
If there is a wheel on the back that is raised and lowered with a hydraulic cylinder, it's semi mounted. If it has a fixed gauge wheel or no gauge wheel it is fully mounted.
Edited by CTuckerNWIL - 07 Dec 2011 at 6:28pm
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2011 at 6:55pm
Trip bottoms makes it an 80 unless the trips were added as options to the 70 or 60 frames. The 70 and 80 frames are adjustable width, the 60 frames are fixed width. That one pictured is a 60. The basic frames could be set up for three point, snap coupler, semi mounted, or full mounted by the trailing wheel and hitch section options. And the side mounted depth gauge wheel was another option. Plus all the options for choice of bottom. It must have taken more than one number on a slip of paper, more like half a page of options to place an order for one plow.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2011 at 7:02pm
10-4, got her now. Its definetly a fully mounted plow then.
Will hopefully have pics up this weekend, be on the lookout.
Galatians 5:22-24
Cary(KY) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cary(KY) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2011 at 8:32am
Does anyone know of a good source for springs? My nieghbor broke one on a Ford plow and it was unbelivable how much a spring cost. I also need to replace the springs on my bush hog.
Cary
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2011 at 9:12am
Many hardware and farm stores carry a line of springs. Sometimes not big enough for farm machinery. You have to select by wire size and coil diameter and buy something too long and shorten it to fit which is easy for a compression spring, difficult for an extension spring.
McMaster-Carr www.mcmaster.com has a much larger selection.
Gerald J.
Rawleigh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rawleigh Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2011 at 4:20pm
I got springs from Mcmaster Carr to repair my old Burch disc.. They are called Die Springs.  you can stack them to get the right height.  You can also use Belleville Washers as springs by stacking them in pairs with the cups facing each other.
Edited by Rawleigh - 08 Dec 2011 at 4:22pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cary(KY) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2011 at 5:53pm
Thanks, I thought MC might be the place to go. I never thought of stacking for hieght.
Cary
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2011 at 7:26pm
Here is a picture of her tonight, Think I have it bought. And something else orange (Not sayin til its home).
I guess this is a #84 with trips, 5 extra points.
Edited by Don(MI) - 15 Dec 2011 at 7:27pm
Galatians 5:22-24
Auntwayne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Auntwayne Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2011 at 7:37pm
      Is it another Lab ???
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2011 at 8:20pm
nope, its orange paint!! And a good one too!
Galatians 5:22-24
