D19 diesel
ACscott View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACscott Quote  Post ReplyReply Direct Link To This Post Topic: D19 diesel
    Posted: 06 Dec 2011 at 3:49pm
hi guys I really need some help i know its a stupid question but this tractor has been apart for a little over two years. I was wondering if someone could take some close up pictures of the right side of the tractor as your sitting on the seat there is an unknown hole right at the bottam of the block and I need to know what goes there I pretty sure its a line of some sort. I cant see from the pictures off the internet because the frame rail blocks the view. It would be greatly appreciated.
Tim-tn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim-tn Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2011 at 4:22pm
Only hole I can think of on the right side would be turbo drain......
Don(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2011 at 5:03pm
Thats all I can think of, too Tim.
See that steel tube, draining back into the block?
Galatians 5:22-24
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACscott Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2011 at 5:32pm
yes don its on that side and thanks for the picture but its right below that steel line behind the frame rail almost right at the pan. It looks almost like the dipstick hole but its on the other side im pretty sure.
Bob(FL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob(FL) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2011 at 5:43pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACscott Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2011 at 6:23pm
Bob thank you very much for posting that I have circled where the hole is could you or anyone else tell me what is supposed to go there.
Edited by ACscott - 06 Dec 2011 at 6:26pm
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2011 at 6:38pm
Dipstick
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACscott Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2011 at 7:50pm
you may be right gary but i think the dipstick is on the other side because the starter goes over that spot. is there some sort of plug that goes in there?
Edited by ACscott - 06 Dec 2011 at 7:50pm
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2011 at 8:51pm
Combines had the dipstick at that location, there should be a drive in plug that goes in the hole.  I dont know if you can get the plug from AGCO yet, may have to fab somthing.
m16ty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote m16ty Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2011 at 8:53pm
Without going out and looking at my tractor, I'd say the block is made to have the dipstick on either side. If that's the case you need to plug the hole.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2011 at 10:39pm
You have a combine block if it has a dipstick there. The tractor engine uses the left side dipstick. I got my 262 in the tractor before I realized i should have opened up the left side dipstick hole. It's not drilled on mine, and I did not want to pull the oil pan back off, so I did a little grinding on the starter and made do.
