WD45 hand clutch stuck
Denis in MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Denis in MI Quote  Post ReplyReply Direct Link To This Post Topic: WD45 hand clutch stuck
    Posted: 05 Dec 2011 at 10:39pm
Has anybody had a hand clutch in a WD or WD45 stick in the engaged position? I have one that is in a tractor that has sat for many years and wonder of its some thing that will work free or if I need to pull it apart. It still snaps and feels normal but does not affect the motion of the tractor.
Thanks in advance for any help or opinions,
Denis
1938 B, 1945 B, 1941 IB, 1949 C, 2 1938 WCs, 3 1950 WDs, 1951 WD, 2 1955 WD45, 1957 D-14
bdallman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bdallman Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2011 at 10:58pm
I would keep driving it around and popping that hand clutch in and out. Maybe it will free itself up after a few hours of operation etc. I would say if it still doesnt work after that you might wanna start thinking about tearing into the linkages and maybe pulling it apart.
1954 CA, 1952 WD with Freeman Loader,1955 WD45, 1963 D19 Gas, 1984 620H, 1980’s AC Forklift, 66 All Crop Harvester, White Top Roto Baler, Misc S.C. Equip and AC Collectibles.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2011 at 6:29am
The plates have most likely rusted togather. Pull the top off and with it released drive a screwdriver between the plates to seperate them.  MACK
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2011 at 6:31am
i remember a WD45 that Larry Swenson bought that the previous owner had bought it new and never used the hand clutch. It would not work either.  Dave.
Chris (swIA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris (swIA) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2011 at 7:45am
My cousin's 45 had the same problem on a tractor that he used every day. it snapped in and out but never released. He pulled the cover and found that a pin had fallen out of the linkage and wasn't releasing one side. Yours is most likely the plates stuck from sitting.
