Drag disk to SC disk
Josh Day View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh Day Quote  Post ReplyReply Direct Link To This Post Topic: Drag disk to SC disk
    Posted: 04 Dec 2011 at 8:49am
I was wondering if there is any way to convert an old drag type disk to a snap coupler lift disk to pull behind a CA. Does any one have any pics of one? Or is this even possible? Thanks Josh.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2011 at 9:20am
It would be easy enough to put the eye and beam onto the old disc, but your lift arms  grab a rigid frame of the disc to raise it. Lot of old pull discs dont have much of a frame and are kind of floppy in the center. You would need a disc that had a rigid angle iron frame all around it.
stray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stray Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2011 at 9:21am
The one AC drag type disk that I was around I would say "No way." It would have been a load on a CA anyway. If I remember right it was about 8' wide and pivoted in the middle, You had to set both the front and rear halfs to the disired cut angle. I don't know if all the drag type disk that Allis made was this way or not.
1969 190XT series 3
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2011 at 5:22pm
   I don't think Josh is talking about using an Allis Drag Disk.
http://www.rumelyallis.com
powertech84 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote powertech84 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2011 at 6:28pm
I dont think it would be to bad of a job to convert a new compact utility type three point disk to work. I'm thinking like a king cutter, or frontier brand 4-5 ft rig.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh Day Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2011 at 8:04pm
No, any brad of drag disk. I was just thinking of mabey a later project if its not that hard to do.
