another E question.
bakwoodsfarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bakwoodsfarm Quote  Post ReplyReply Direct Link To This Post Topic: another E question.
    Posted: 03 Dec 2011 at 7:29pm
I think I need to rebuild the hyd pump, works ok at first but after a while, it won't lift the head and you can hear it screaming, hot to the touch but full of fluid.
Leesok View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leesok Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2011 at 7:53pm
Is the belt slipping??? If not you are probably right.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bakwoodsfarm Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2011 at 8:07pm
no, the pump just screams.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2011 at 9:34pm
Could have a valve stuck. Work the hyd. levers make sure they center. MACK
