SC plow spare parts..
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Topic: SC plow spare parts..
    Posted: 03 Dec 2011 at 5:10pm
I wanted a 3 point 3-14 plow but could not find a good deal. Bought this SC plow today. Plan is to convert it to 3 point hitch. Will not need the two lift arms, adjustable  tilt link, or the SC eye or beam.. Are they worth anything other than steel price ?
Murph-NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Murph-NC Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2011 at 5:59pm
I'd for sure save the lift arms and SC eye.  I know I've bought one eye from another member (for more than scrap price, but still a good deal), and I'm sure you'll find someone needing one eventually... probably true for the lift arms too.
'41 C w/Woods L503 mower, #3 mower, 2-way plows for C
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2011 at 6:09pm
I'd like the lift arms and the SC eye.  I need the eye yesterday!  LOL  PM me with a price.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2011 at 6:18pm
guys, i dont have a  CLUE  of the price. Im not trying to get rich. I really DONT KNOW.  I have 3  PMS asking prices... thats what i want to know.
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2011 at 8:43pm
   Steve, if you make that three point, where are you going to mount the front coulter ?
http://www.rumelyallis.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2011 at 8:49pm
how about running the coulter arm straight up to the center top link bracket area and putting a "short"  6-8 inch long beam in place of the SC beam... thats why i want to know if its worth selling or cutting.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2011 at 9:22pm
   Steve, The coulter needs to be able to move left and right some. I'm also not sure if you will be able to get the draft anywhere near right doing this. What tractor are ya gonna put this on ? You couldn't find any allis, IH, ferguson, ford or dearborn 3 pt. plows around ?
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2011 at 9:26pm
Steve, I've been selling the pieces for $20 bucks a piece. Doesn't matter what it is, it makes it easier for this old man to remember the price.
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2011 at 9:31pm
Didn't one of those sc eyes bring over $40 on ebay a couple of years ago??
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2011 at 5:00pm
Well, here is a picture  today with all the spare SC parts removed. Cross shaft was setting 6 inches behind the tip of the front bottom, so i cut the SC beam and added a foot to each side.  Cross shaft is just wired onto position to show how it will look. I looked on e-bay at a dozen 3 point plows and looks like the cross shaft is normally forward a few inches of the front point. This plow will go on a tractor that has a drawbar beam (front to back) about 4 inches from the lift arm ends, so i wanted a couple extra inches of clearance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2011 at 5:04pm
Im thinking of turning the left end of the cross shaft down to 1-1/8 inch to fit the 3 point arm. On the right side, maybe take a 4 x 8 plate about 3/4 inch thick and hang it over the cross shaft  pointing down, then mount a 1-1/8 inch pin onto the plate so the RIGHT  side is 4 inches lower than the left.  Still wondering if i need to make it adjustable front to rear for bottom alignment, or can i  fix it vertically below the cross shaft.
Edited by steve(ill) - 04 Dec 2011 at 5:05pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2011 at 4:44pm
Cross shaft turned to size and mounted. 4 inch drop on the right side. Original upright  frame mounted and anchored to rear of main frame. Just have to add adjustable arm from right side of cross shaft back to frame for  plow adjustment... then clean and paint.
